I suspect that the issue lies downstream from the router, probably with your ISP.
Itās still running fine without any disconnections, so Iām going to take the Wemos offline because I think weāve proven the point.
Iāll flash the Wemos with a blank sketch so that it doesnāt connect next time I plug it in, to avoid any confusion at your end.
Thank you Pete
I will try a couple of things on my router and if everything fails, Iāll speak to my ISP.
A little bit of positive news,
My other D1 mini which was running my main sketch was online for the longest it has been for awhile!
Almost an entire day without a single disconnect. It unfortunately went offline 1 and a half hours ago.
I hope to be free this weekend to have a look at my router settingsā¦
Edit: The Blynk protocol is non-edgent, port 80 sketchā¦
Update:
Still disconnecting from Blynk servers and SM output is continous āConnect to blynk.cloud:80ā
My last idea is to continously check if the board is connected to blynk servers and if it is not, reboot the board.
if(!Blynk.connected())
ESP.restart();
This code doesnāt seem to work as the board does automatically reboot when the ā(!Blynk.connected()ā is metā¦
What are options
I donāt understand this statement.
I think the bottom line is to establish what the primary cause of the issue is - and I suspect itās your ISP - and fix that problem.
Apologies for the typo.
I meant the board does not reboot when the ā(!Blynk.connected())ā condition is met. It appears to return ātrueā even though itās attempting to reconnect to the server. I read another discussion of the same issue.
I spoke to my ISP, unsurprisingly the technician didnāt have a clue what Blynk is and I had to briefly explain it. After a good 10mins of on and off hold, they said there are no restrictions in place for Blynk and any other IoT platforms.
They then suggested the same old restart the router and try againā¦.
I agree with you Pete about finding the root cause instead of taking a short cut. I am ashamed to come to a point where I still havenāt solved this and my last option being to add a line of code to patch the bugā¦.
Iāve even thought of adding an arduino with a relay to reboot the wemos every āXā hours by interrupting the powerā¦
Iām desperate to keep the device running and online continuously without me having to reset it.
This week I will try connecting the wemos to its own router (only device connected). Hoping for positive resultsā¦.
You should probably post the code you are using.
It might be worth reading this, then having another chat with the technicianā¦
Pete I made an interesting discovery.
I disconnected the fiber cable from the router to simulate a internet blackout and the wemos attempts to connect to blynk.cloud (as expected). However, when I reconnect the fiber cable back to the router and confirm on my phone that the internet connection as been restored, the wemos however still attemps to connect to blynk.cloud.
So what I believe is happening is that theres brief internet blackout, and the wemos gets stuck on a loop trying to establish a connection with the sever, even after the internet has been restored.
So this comfirms that it has nothing to do with my ISP blocking Blynk servers. The wemos is simply unable to reconnect to blynk server on its own after an internet blackout.
Any suggestion on how I can fix this?
Please see attached SM output and code below
At timestamp 17:52:47.361, the board has succefully connected to the server.
At timestamp 18:05:51.544, I unplugged the fiber line to simulate a internet blackout
At timestamp 18:07:03.074, I reconnected the fiber line and comfirmed internet is restored
17:52:47.327 ->
17:52:47.327 -> [8533] Connecting to blynk.cloud:80
17:52:47.361 -> [8688] Ready (ping: 56ms).
18:05:51.544 -> [792882] Connecting to blynk.cloud:80
18:05:57.562 -> [798884] Connecting to blynk.cloud:8080
18:06:04.660 -> [805988] Connecting to blynk.cloud:80
18:06:10.659 -> [811989] Connecting to blynk.cloud:8080
18:06:17.775 -> [819093] Connecting to blynk.cloud:80
18:06:23.751 -> [825094] Connecting to blynk.cloud:8080
18:06:30.856 -> [832197] Connecting to blynk.cloud:80
18:06:36.875 -> [838199] Connecting to blynk.cloud:8080
18:06:43.977 -> [845302] Connecting to blynk.cloud:80
18:06:49.967 -> [851303] Connecting to blynk.cloud:8080
18:06:57.081 -> [858407] Connecting to blynk.cloud:80
18:07:03.074 -> [864408] Connecting to blynk.cloud:8080
18:07:10.175 -> [871512] Connecting to blynk.cloud:80
18:07:16.188 -> [877513] Connecting to blynk.cloud:8080
18:07:23.293 -> [884617] Connecting to blynk.cloud:80
18:07:29.305 -> [890618] Connecting to blynk.cloud:8080
18:07:36.404 -> [897721] Connecting to blynk.cloud:80
18:07:42.380 -> [903723] Connecting to blynk.cloud:8080
18:07:49.508 -> [910826] Connecting to blynk.cloud:80
18:07:55.506 -> [916828] Connecting to blynk.cloud:8080
18:08:02.606 -> [923931] Connecting to blynk.cloud:80
18:08:08.594 -> [929932] Connecting to blynk.cloud:8080
18:08:15.693 -> [937036] Connecting to blynk.cloud:80
18:08:21.711 -> [943037] Connecting to blynk.cloud:8080
18:08:28.807 -> [950141] Connecting to blynk.cloud:80
18:08:34.818 -> [956142] Connecting to blynk.cloud:8080
18:08:41.904 -> [963246] Connecting to blynk.cloud:80
18:08:47.928 -> [969247] Connecting to blynk.cloud:8080
18:08:55.015 -> [976351] Connecting to blynk.cloud:80
18:09:01.017 -> [982352] Connecting to blynk.cloud:8080
Code
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME "Yamaha EF5500EFW"
#define BLYNK_AUTH_TOKEN ""
#define BLYNK_FIRMWARE_VERSION "5.5"
//#define BLYNK_DEBUG
#define APP_DEBUG
#define BLYNK_GREEN "#23C48E"
#define BLYNK_RED "#D3435C"
#define BLYNK_YELLOW "#ED9D00"
int CEBsensor = 0;
int CEBstate = 0;
int Timerstate = 0;
int InvTimerstate = 0;
int inverterstate = 0;
//Voltage Sensor
//int Vsensor = A0;
float correctionfactor = 7.40;
float vout = 0.0;
float vin = 0.0;
float fuelcon = 0.0;
//float R1 = 30000;
//float R2 = 7500;
//int value = 0;
//Declare millis for timers
unsigned long msec = 0;
unsigned long msec2 = 0;
float times = 0.0;
float hourmeter = 0.0;
//Blynk LED Widgets
WidgetLED led1(V3); //COIL LED
WidgetLED led2(V7); //FUEL LED
WidgetLED led3(V4); //STARTER LED
WidgetLED led13(V13); //GENERATOR SHUTOFF LED
WidgetLED led14(V14); //CEB STATUS LED
WidgetLED led15(V18); //INVERTER STATUS LED
WidgetLED led16(V20); //INVERTER SHUTOFF LED
WidgetLED led17(V24); //CHANGEOVER RELEASE INDICATOR
int newTimer = 1;
char ssid[] = "";
char pass[] = "";
String error;
pinMode(D0, OUTPUT); //STARTER Relay D0
pinMode(D5, OUTPUT); //FUEL Relay D5
pinMode(D6, OUTPUT); //COIL Relay D6
pinMode(D7, OUTPUT); //INVERTER Relay D7
pinMode(D1, INPUT); //CEB LDR Sensor D1
//pinMode(Vsensor, INPUT); //Voltage Sensor A0
//(To prevent self-trigger during initial boot)
digitalWrite(D0, HIGH); //D0
digitalWrite(D5, HIGH); //D5
digitalWrite(D6, HIGH); //D6
timer.setInterval(10000L, CEBsensor1);
timer.setInterval(1000L, runtime);
timer.setInterval(1000L, invertertime);
//timer.setInterval(10000L,Voltagesensor1);
//timer.setInterval(1000L, stats);
if (WiFi.status() != WL_CONNECTED && !Blynk.connected())
ESP.restart();
BLYNK_CONNECTED() {
Blynk.syncVirtual(V10, V18); //Works, Doesn't get triggered when not on
void stats () {
ESP.wdtFeed();
if (WiFi.status() != WL_CONNECTED)
ESP.restart();
if (!Blynk.connected())
ESP.restart();
void invertertime()
if (CEBstate == LOW) {
if (inverterstate == HIGH) {
led15.on();
Blynk.setProperty(V10, "color", "#23C48E");
Blynk.setProperty(V18, "color", "#23C48E"); //Inverter Status (ON) GREEN
digitalWrite(D7, HIGH); //INV RELAY ON D7
delay(100);
Blynk.setProperty(V2, "offLabel", "OFF Inverter Before Starting");
Blynk.setProperty(V2, "onLabel", "OFF Inverter!");
Blynk.setProperty(V18, "color", "#ED9D00"); //Inverter Status (OFF) Yellow
Blynk.setProperty(V10, "color", "#ED9D00");
digitalWrite(D7, LOW); //INV RELAY OFF D7
delay(100);
Blynk.setProperty(V2, "offLabel", "Hold to Start");
Blynk.setProperty(V2, "onLabel", "Release");
if (inverterstate == HIGH && CEBsensor == LOW) {
led16.on(); //Inverter Shutoff Indicator ON
yield();
led16.off(); //Inverter Shutoff Indicator OFF
yield();
void runtime()
if (CEBstate == HIGH && Timerstate == HIGH) {
times = ((millis() - msec));
Blynk.setProperty(V16, "label", "Current Generator Run Time");
Blynk.setProperty(V17, "label", "Current Fuel Consumption");
String readableTime;
getReadableTime(readableTime);
Blynk.virtualWrite(V16, readableTime);
Blynk.virtualWrite(V17, 1.7 * ((millis() - msec) / 1000) / 3600);
delay(500);
if (InvTimerstate == HIGH && CEBstate == LOW && Timerstate == LOW) {
times = ((millis() - msec2));
Blynk.setProperty(V16, "label", "Inverter Run Time");
delay(500);
void getReadableTime(String & readableTime) {
unsigned long currentMillis;
unsigned long seconds;
unsigned long minutes;
unsigned long hours;
unsigned long days;
currentMillis = times;
seconds = currentMillis / 1000;
minutes = seconds / 60;
hours = minutes / 60;
days = hours / 24;
currentMillis %= 1000;
seconds %= 60;
minutes %= 60;
hours %= 24;
if (days > 0) {
readableTime = String(days) + " ";
if (hours > 0) {
readableTime += String(hours) + "H:";
if (minutes < 10) {
readableTime += "0";
readableTime += String(minutes) + "m:";
if (seconds < 10) {
readableTime += String(seconds) + "s";
BLYNK_WRITE(V1)
//attach Button on virtual V1,
//it will control the Coil
if (param.asInt() == 1) {
delay(100);
digitalWrite(D6, LOW); //COIL RELAY ON D6
delay(100);
led1.on();
msec = millis();
CEBstate = 1;
if (param.asInt() == 0) {
delay(100);
digitalWrite(D6, HIGH); //COIL RELAY OFF D6
delay(100);
led1.off();
CEBstate = 0;
Blynk.setProperty(V16, "label", "Previous Generator Run Time");
Blynk.setProperty(V17, "label", "Previous Fuel Consumption");
//Blynk.setProperty(V23, "isDisabled", true);
delay(100);
Blynk.logEvent("generator_off");
BLYNK_WRITE(V2)
//attach Button on virtual V2,
//it will control the Starter
if (param.asInt()) {
newTimer = timer.setTimeout(2000, Starter); // button pressed for >2Sec
else {
timer.disable(newTimer);
void Starter()
if (inverterstate == LOW) {
led3.on();
digitalWrite(D0, LOW); //STARTER CRANK ON D0
delay(1200); //CRANK DURATION
digitalWrite(D0, HIGH); //STARTER CRANK OFF D0
led3.off();
Blynk.logEvent("generator_on");
BLYNK_WRITE(V9)
//attach Button on virtual V9,
//This will control the Fuel
delay(100);
digitalWrite(D5, LOW); //FUEL RELAY ON D5
delay(100);
led2.on();
Timerstate = 1;
delay(100);
digitalWrite(D5, HIGH); //FUEL RELAY OFF D5
delay(100);
led2.off();
Timerstate = 0;
BLYNK_WRITE(V10)
//attach Button on virtual V10,
//it will control the Inverter Relay
inverterstate = 1;
msec2 = millis();
InvTimerstate = 1;
Blynk.logEvent("inverter_on");
Blynk.setProperty(V22, "isDisabled", true);
Blynk.setProperty(V23, "isDisabled", false);
inverterstate = 0;
InvTimerstate = 0;
Blynk.logEvent("inverter_off");
Blynk.setProperty(V22, "isDisabled", false);
BLYNK_WRITE(V15)
//attach Button on virtual V15,
//This will update System Status
Blynk.virtualWrite(V8, map(WiFi.RSSI(), -110, -30, 30, 100));
BLYNK_WRITE(V19)
//attach Button on virtual V19,
//This will reset Coil/Fuel Status
Blynk.virtualWrite(V1, 0);
led1.off();
Blynk.virtualWrite(V9, 0);
led2.off();
delay(100);
Blynk.setProperty(V16, "label", "Previous Run Time");
delay(100);
Timerstate = 0;
CEBstate = 0;
void CEBsensor1()
//Run every second
CEBsensor = digitalRead(D1); //LDR Sensor
Blynk.virtualWrite(V12, CEBsensor);
//If COIL ON and CEBsensor LOW, Trigger "Grid Restored" Blynk Automation
if (CEBsensor == LOW && CEBstate == HIGH) {
led13.on(); //Shutoff Indicator ON
yield();
led13.off(); //Shutoff Indicator OFF
yield();
//CEB STATUS LED
if (CEBsensor == HIGH) {
led14.on();
Blynk.setProperty(V14, "color", "#D3435C"); //CEB Status (ON) RED
Blynk.logEvent("grid_failure");
yield();
Blynk.setProperty(V14, "color", "#23C48E"); //CEB Status (ON) GREEN
yield();
void Voltagesensor1()
//Run every 10 sec
int sdata = 0;
value = analogRead(Vsensor);
vout = (value * 5.0) / 1024.0;
vin = vout / (R2 / (R1 + R2));
vin = vin - correctionfactor;
Blynk.virtualWrite(V5, vin);
yield();
if (vin < 12.0) {
Blynk.setProperty(V5, "color", "#D3435C"); //If UPS Voltage < 12.5v, Gauge RED
Blynk.setProperty(V5, "color", "#F7CE46"); //If UPS Voltage > 12.5v, Gauge ORANGE
//BETA
BLYNK_WRITE(V22)
//attach Button on virtual V22,
//it will control the GENtoINV
newTimer = timer.setTimeout(2000, GENtoINV); // button pressed for >2Sec
else {
void GENtoINV()
led17.on();
//FUEL
led1.off();
delay(100);
CEBstate = 0;
delay(100);
delay(1500);
//COIL
led2.off();
delay(100);
Timerstate = 0;
delay(2000);
//INV Relay
Blynk.virtualWrite(V10, HIGH);
inverterstate = 1;
msec2 = millis();
InvTimerstate = 1;
led17.off();
BLYNK_WRITE(V23)
//attach Button on virtual V23,
//it will control the INVtoGEN
newTimer = timer.setTimeout(2000, INVtoGEN); // button pressed for >2Sec
else {
void INVtoGEN()
//INV RELAY OFF
led17.on();
inverterstate = 0;
InvTimerstate = 0;
Blynk.virtualWrite(V10, 0);
delay(100);
delay(3000);
//FUEL
Blynk.virtualWrite(V9, 1);
led2.on();
Timerstate = 1;
delay(1500);
//COIL
Blynk.virtualWrite(V1, 1);
led1.on();
msec = millis();
CEBstate = 1;
delay(2000);
//STARTER
led3.on();
led3.off();
led17.off();
You need to stop using Blynk.begin, and switch to managing your own WiFi connection and using Blynk.config and Blynk.connect.
You then need to have timed functions that check if youāre still connected to WiFi and to Blynk, and that re-connect where necessary.
Noted. I refered to this discussion and code and implemented certain parts for testing. So far so good, the board reboots when it detects a loss of connection to the servers. I will continue testing and hopefully the issue has been solved.
Good news!
The issue appears to be solved and the board has stayed online for 2 days. Within the 2 days it has lost connection to the server, but after implementing parts from the above attached discussion, the board automatically reboots and restores connection to the server, thus fixing the issue.
I am really happy with this result. My project is now online and everything is working as expected.
Its been a month of diagnosing this simple matter but I really appriciate your help Pete. Thank you.
Heres a summary for anyone new of the issue I faced.
My D1 mini would go offline multiple times a day and would not reconnect to the Blynk server automatically. After concluding that it wasnāt my code nor my ISP blocking Blynk, I discovered that my internet connection would have multiple black outs per day. Therefore when a blackout occurs, the board looses connection to the server (expected), however when the internet connection is restored, the board continues to āConnecting to Blynk.cloud:80ā till I manually reboot it.
You do t need to reboot the server, just re-establish the Blynk and/or WiFi connection.
