I am trying to connect my first Quickstart device, I used the quickstart tour, just pasted mi WiFi SSID and password and copied and pasted the code in Arduino IDE, uploaded to ESP32 and it doesn’t connect The output I get on the Serial monitor is:
20:24:39.168 → ets Jul 29 2019 12:21:46
20:24:39.201 →
20:24:39.201 → rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
20:24:39.201 → configsip: 0, SPIWP:0xee
20:24:39.201 → clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
20:24:39.201 → mode:DIO, clock div:1
20:24:39.201 → load:0x3fff0018,len:4
20:24:39.201 → load:0x3fff001c,len:1216
20:24:39.201 → ho 0 tail 12 room 4
20:24:39.201 → load:0x40078000,len:10944
20:24:39.201 → load:0x40080400,len:6388
20:24:39.201 → entry 0x400806b4
20:24:39.452 → [24] Connecting to Totalplay-31AA-5G
HiLetgo ESP32 device with 38 GPIOs bulit-in WiFi
Android
Blynk server
Blynk Library version 1.1.0
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPL4IrEUQnI"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "qnA-OmchyP7Yx7PaJqpE0sAfAlif064e"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "MyNetwork";
char pass[] = "MyPassword";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
¿May I have some help please? Thanks!
