There is no “default” map size. The map is zoomed out just when there were no pins added yet.
Button on the top right zooms to show all pins visible.
Button on the bottom right zooms to your location.
You can set custom location/zoom by pinching the map.
And map follows newly added pins so the user is aware of changes. So, I don’t quite understand your needs here.
