Question about run multiple function
I use virtualpin to call some function, but I don’t know how to call function one bye one after a time like delay, example:
BLYNK_WRITE(V1)
function1();
“pause time”
function2();
“pause time”
function3();
sorry my bad English
you need simpletimer library
timer.setTimeout(1000L, function1);
calls function1 after 1 second
Thanks for your help, anyway else, simple timer work with function, how about code, example
BLYNK_WRITE(V1) { some code abc "pause time" some code bcd "pause time" some code efg }
i don’t know enough about code to tell you how you should code it, i just know that simpletimer is probably what you should use :slight_smile:
learn about it here: http://playground.arduino.cc/Code/SimpleTimer
Hi @NHN,
Have a look at this structure, I think it can do what you want.
This is not the complete code! Only the main items:
int sequence=0; // variable to be used for your functions
timer.setInterval(1000L, run_sequence); //Define the time between intervals
void run_sequence()
 if (sequence == 0){
  //some code A;
 if (sequence == 1){
  //some code B;
   if (sequence == 2){
  //some code C;
if (sequence <= 2) {
     sequence++;
else {
    sequence = 0;  // Reset the sequence to start again
With this code you would obtain a sequence like A, B, C ,A ,B ,C… every second.
Hope it helps!
thanks very much. I think your code is best way :smiley:
See, i only know WHAT to use, people like @psoro know HOW to use it :slight_smile:
I just know where to ask. Sometime don’t know how to ask :smiley:
