Quero assear o blink pelo pc
Boa noite .uso seus aplicativo e estou gostando muito mas na minha casa uso meu arduino também nos pc . hoje estou usando uma biblioteca minha junto com a suas instalado no arduino funciona mas quando a internet cai tenho que ir la e resetar o arduino manualmente gostaria de saber se à posibilidade de usar um software pc
Please use English if possible. I did try Google Translate, but it did not make any more sense :slight_smile:
Good night. I use your app and I'm really enjoying it but in my house I use my arduino also in the pc. Today I am using a library of mine along with its installed in arduino works but when the internet drops I have to go la and reset the arduino manually I would like to know if the possibility of using a pc software
We don’t have a PC software yet.
Meanwhile you can use an emulator as Droid4x for example. It works like a charm.
You know the arduino library.
Because tonight I realized that when the light goes away and when I order to record the library of the Arduino along with his he shows error in my library but he continues saving
AllAvailPins.ino - Expose All Available Pins on Arduino UNO for EthernetSup Library.
Created by Carlos Magno, Jan 19, 2016.
Released into the public domain.
#include <Ethernet.h>
#include “EthernetSup.h”
char auth = “*****************************”;
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip = { 192, 168, 0, 99 };
// Todas as portas disponiveis do ATMega328p
// Exceto Serial e ISP
const char porta1 = 23;
const char porta2 = 25;
const char porta3 = 27;
const char porta4 = 29;
const char porta5 = 31;
const char porta6 = 33;
const char portaFechadura = 35;
const char portaGaragem = 37;
const char porta9 = 39;
const char porta10 = 40;
const char porta11 = 41;
const char porta12 = 42;
const char porta13 = 43;
const char porta14 = 47;
EthernetSup sup;
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, “your_server.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,0,4), 8442);
// Iniciando Ethernet
sup.begin(mac, ip);
// Configurando portas dos botoes
pinMode(porta1, OUTPUT);
pinMode(porta2, OUTPUT);
pinMode(porta3, OUTPUT);
pinMode(porta4, OUTPUT);
pinMode(porta5, OUTPUT);
pinMode(porta6, OUTPUT);
pinMode(portaFechadura, OUTPUT);
pinMode(portaGaragem, OUTPUT);
pinMode(porta9, OUTPUT);
pinMode(porta10, OUTPUT);
pinMode(porta11, OUTPUT);
pinMode(porta12, OUTPUT);
pinMode(porta13, OUTPUT);
pinMode(porta14, OUTPUT);
// Estado incial das portas
digitalWrite(porta1, LOW);
digitalWrite(porta2, LOW);
digitalWrite(porta3, LOW);
digitalWrite(porta4, LOW);
digitalWrite(porta5, LOW);
digitalWrite(porta6, LOW);
digitalWrite(portaFechadura, LOW);
digitalWrite(portaGaragem, LOW);
digitalWrite(porta9, LOW);
digitalWrite(porta10, LOW);
digitalWrite(porta11, LOW);
digitalWrite(porta12, LOW);
digitalWrite(porta13, LOW);
digitalWrite(porta14, LOW);
sup.addButton(porta1, “Luz da varanda 6”, ONOFF_BUTTON);
sup.addButton(porta2, “Luz da varanda A”, ONOFF_BUTTON);
sup.addButton(porta3, "Luz do muro ", ONOFF_BUTTON);
sup.addButton(porta4, “Luz da garagem”, ONOFF_BUTTON);
sup.addButton(porta5, "Luz da cobertura “, ONOFF_BUTTON);
sup.addButton(porta6, “Cerca eletrica”, PULSE_BUTTON);
sup.addButton(portaFechadura, “Saida da av A”, PULSE_BUTTON);
sup.addButton(portaGaragem, “Portao garagem”, PULSE_BUTTON);
sup.addButton(porta9, “Luz do muro rua 6”, ONOFF_BUTTON);
sup.addButton(porta10, “Luz da cozinha”, ONOFF_BUTTON);
sup.addButton(porta11, “cozinha a lenha”, ONOFF_BUTTON);
sup.addButton(porta12, “Luz da sala”, ONOFF_BUTTON);
sup.addButton(porta13, “Luz da copa”, ONOFF_BUTTON);
sup.addButton(porta14, " Area de tanque”, ONOFF_BUTTON);
// Load HTML
if (sup.available())
// Verifica se algum botao foi pressionado
int lastButton = sup.getLastClickedButton();
// Executa o comando conforme o botao clicado
switch (lastButton)
  case porta1:
    digitalWrite(porta1, sup.getButtonState(lastButton));
    break;
  case porta2:
    digitalWrite(porta2, sup.getButtonState(lastButton));
    break;
  case porta3:
    digitalWrite(porta3, sup.getButtonState(lastButton));
    break;
  case porta4:
    digitalWrite(porta4, sup.getButtonState(lastButton));
    break;
  case porta5:
    digitalWrite(porta5, sup.getButtonState(lastButton));
    break;
  case porta6:
    digitalWrite(porta6, HIGH);
    delay(300);
    break;
  case portaFechadura:
    digitalWrite(portaFechadura, HIGH);
    delay(500);
    break;
  case portaGaragem:
    digitalWrite(portaGaragem, HIGH);
    delay(500);
    break;
  case porta9:
    digitalWrite(porta9, sup.getButtonState(lastButton));
    break;
  case porta10:
    digitalWrite(porta10, sup.getButtonState(lastButton));
    break;
  case porta11:
    digitalWrite(porta11, sup.getButtonState(lastButton));
    break;
  case porta12:
    digitalWrite(porta12, sup.getButtonState(lastButton));
    break;
  case porta13:
    digitalWrite(porta13, sup.getButtonState(lastButton));
    break;
  case porta14:
    digitalWrite(porta14, sup.getButtonState(lastButton));
    break;
  default:
    break;
// Novo metodo para limpar estado
// do botao somente no final
sup.clearButtonIdx();
// Delay
Code snippets should be formatted. Please edit your initial post:
How to do that:
 ``` cpp <--put 3 backticks BEFORE your code starts  ("cpp" means C++ language)
   //Put your code here
 ``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
