I setup a local server. So far everything is working.
When I try to share my project the QR Code is created and I send it out.
If we try to access the project it does not connect. I found that the link does not have the right server address.
For example, the generate URL is:
blynk://token/projpriv/36760be1e5e04ac5b81cf8383ffe235b?username=user%40gmail.com&server=2604&port=8443&dashId=508431107&dashTitle=ESP%20%40%20Home
Note the 2604 after server=
If I correct it by replacing the 2604 with my server address and recreate the QR Code (using http://www.qr-code-generator.com/), then it works no problem.
I am wondering where that 2604 comes from and where can I configure it…
Thanks a bunch
