Hi All,
I made a simple script/circuit in which temp data is read and passed to the Blynk app. Seems to connect fine and the correct reading is displayed in the app. However, the temperature value does not update in the app unless I leave the app and return, or restart the app.
The temp sensor is the bmp180 and I am using the Adafruit library. Connected via I2C on pins 21 and 22.
In case it is relevant, I am using Google Pixel 3 phone.
I’ve read through the “keep the loop clean” and such. I am not using any delay() either. Below is the script I am using:
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Removed these and replaced with ZZZ, YYY, XXX
char auth[] = "ZZZ";
char ssid[] = "YYY";
char pass[] = "XXX";
Adafruit_BMP085 bmp;
Wire.begin(21,22);
bmp.begin();
timer.setInterval(1000L, temp_reading);
void temp_reading(){
float temp = bmp.readTemperature();
Blynk.virtualWrite(V1, temp);
Serial.println(temp);
