I have tried my best to enable this piece of code to work but all in vain I have also read all the previous questions related to it but none of them helped me out in this problem Please Can you check my code if there is any mistake i am making or any improvement than can be made there?
Please help me bro
@Gunner @Costas @Dmitriy @Pavel @Jamin
My code is
#define BLYNK_PRINT SwSerial
//char auth[] = "95b6eeef38fe481dba590c28febef4bb"; // For Blynk Cloud Server
char auth[] = "1ec485252d9542b999bc8766edc08172"; // For Local Server
int pinValue = 0;
BLYNK_WRITE(V7)
pinValue = param.asInt();
void myTimerEvent()
//------------------Automatic Switching Code-----------------------//
double solar = analogRead(A1);
float voltage = solar*(5.0/(1023*0.2000818));
//----------------------------END----------------------------------//
//----------------Reading The condition of Relay 2 i.e Generator----------------//
const int Relay2_Signal_Pin = 4;
int G = digitalRead( Relay2_Signal_Pin);
//-------------------------------------END--------------------------------------//
//-----------------------------Sending Value of digital and analog pin to the display widget-----------------------------//
//int Digitalpin = analogRead(Relay2_Signal_Pin);
//Blynk.virtualWrite(V3,Digitalpin);
Blynk.virtualWrite(V3,G);
Blynk.virtualWrite(V4,voltage);
//---------------------------------------------------END-----------------------------------------------------------------//
//-------------------------------Defining the virtual pin for Termina widget---------------------------//
WidgetTerminal terminal(V8);
//-------------------------------------------------END-------------------------------------------------//
//--------------------------------------Coding for Terminal Widget-------------------------------------//
int acload = digitalRead(2);
if(acload>0)
terminal.println("AC Load is turned ON");
{terminal.println("AC Load is off");}
terminal.flush();
//if(!acload)
//-----------------------------------------------------END-------------------------------------------//
//-------------Load indication system for Blynk------------------//
//int acload = digitalRead(2);
if(digitalRead(2))
{Blynk.virtualWrite(V1,255);}
//terminal.println("AC Load is turned ON");
//else
//{terminal.println("AC Load is off");
//terminal.flush();}
//if(!acload)
Blynk.virtualWrite(V1,0);
if(digitalRead(13))
Blynk.virtualWrite(V2,255);
Blynk.virtualWrite(V2,0);
//--------------------END--------------------------------//
//------------------------Indication System-------------------------//
if(voltage<1)
Blynk.virtualWrite(V5, 0);
if(!G)
{Blynk.virtualWrite(V6, 255);
Blynk.virtualWrite(V7, 0);}
if(G)
{ //delay(1L * 1000L); //Is commented out just for checking in proteus virtual simulation , include it in real programming
Blynk.virtualWrite(V6, 0);
Blynk.virtualWrite(V7,255);
{Blynk.virtualWrite(V5, 255);
Blynk.virtualWrite(V6,0);
Blynk.virtualWrite(V7,0);}
//-----------------END----------------//
//-----------------------------------------Notification Coding--------------------------------------------//
void notifyOnButtonPress()
// Invert state, since button is "Active LOW"
int isButtonPressed = !digitalRead(7);
if (isButtonPressed) {
SwSerial.println("Button is pressed.");
// Note:
// We allow 1 notification per 15 seconds for now.
Blynk.notify("Yaaay... button is pressed!");
//--------------------------------------------END---------------------------------------------------------//
pinMode(A1,INPUT);
/*pinMode(A1,INPUT);
pinMode(13,OUTPUT);
pinMode(2,OUTPUT);
pinMode(4,OUTPUT);*/
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// timer.setInterval(6000L, notifyOnButtonPress);
//--------------------------Notification Code----------------------------------//
Blynk.notify("Device started");
// Setup notification button on pin 2
pinMode(7, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(7), notifyOnButtonPress, CHANGE);
//--------------------------------END------------------------------------------//
