Push button and Virtual Button (not switch)
Hello All,
I am working with a Adafruit Feather huzzah.
Set-up
Servo Pin 5
Puss button pin 8
Virtual Pin 2
My project consist on controlling a stepper motor with a virtual pin in push button mode. So far, I have this step already completed, the stepper reach 90 degrees and goes back to initial position.
My problem is that I need to connect a physical push button doing the same procedure, I been reading examples but all of them are related to the sync of the buttons working in switch mode for example to turn on a light with the physical button and turn off with the virtual button, that is not my case.
#include <Servo.h>
Servo servo1;
#define SERVO1 5
char auth[] = "*************";
char ssid[] = "*******************";
char pass[] = "***********************";
// Set your LED and physical button pins here
const int btnPin = 8;
void checkPhysicalButton();
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V2);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
  int pinData = param.asInt();
  Blynk.email("***********************", "Cat Feeder", "Hey, your pet feeder here! I just fed your cat!");
  servo1.write(0);
  delay(150);
  servo1.write(90);
  if (digitalRead(btnPin) == LOW) {
    if (btnState != LOW) {
  //Blynk.notify("Hey! I just fed your cat!");
  Blynk.email("heyleen70@gmail.com", "Cat Feeder", "Hey, your pet feeder here! I just fed your cat!");
  servo1.write(0);
  delay(150);
  servo1.write(90);
      // Update Button Widget
    btnState = LOW;
    btnState = HIGH;
  pinMode(btnPin, INPUT_PULLUP);
  Blynk.email("************", "Cat Feeder", "Hey, your pet feeder here! I just fed your cat!");
  servo1.write(0);
  delay(150);
  servo1.write(90);
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
@HeyAndre: Some initial changes I’d make:
  • delete Blynk.virtualWrite(V2); from checkPhysicalButton()
  • change timer.setInterval(100L, checkPhysicalButton); to timer.setInterval(300L, checkPhysicalButton);
In general delay() used with Blynk is not a good idea (see documentation). But, let’s leave that for later.
There is another sketch that I been trying but the buttons does not reflect any action
#include <Servo.h>
Servo servo1;
#define SERVO1 5
char auth[] = "5e24d93aa5be4bc1ab55e1b847c65100";
char ssid[] = "****************";
char pass[] = "**************";
  servo1.attach(SERVO1);
  pinMode(0, INPUT_PULLUP);
BLYNK_WRITE(V1) { //Button Widget is writing to pin V1
  Blynk.email("**********************", "Cat Feeder", "Hey, your pet feeder here! I just fed your cat!");
  servo1.write(0);
  delay(150);
  servo1.write(90);
  //read the pushbutton value into a variable
  int sensorVal = digitalRead(8);
  //print out the value of the pushbutton
  Serial.println(sensorVal);
  // Keep in mind the pullup means the pushbutton's
  // logic is inverted. It goes HIGH when it's open,
  // and LOW when it's pressed. Turn on pin 13 when the
  // button's pressed, and off when it's not:
  if (sensorVal == LOW) {
    servo1.write(0);
    delay(900);
    servo1.write(90);
Please visit docs.blynk.cc and swarch for “state sync”
