Hi all, I would like to know if I can access the widget properties Step H for the minimum and maximum set.
This is very important not to define these values in the software.
Thank you
Hi, thanks for the quick reply but would like to know what instruction should I use to read properties.
Thank you.
afaik, this is not possible in the current version
Correct. However, you may use any other pin to store those values and use SYNC for them.
Hi, Ok thanks for the info and hopefully in the future there is the possibility to read properties.
Thank You
