My blynk project is constantly going OFF… Somedays it work, and somedays it is Offline… Need to restart all the time
you know why?
I’m using the same code. I didn’t change the code.
I tested with other Arduino, and other Ethernet shield and the problem keeps.
But i’m having these days a VERY LOW net speed (like 1mb or 2) will that be cause???
Code:
#include <Ethernet.h>
#include <DHT.h>
#define W5100_CS 10
#define SDCARD_CS 4
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
WidgetBridge bridge1(V1);
static bool value = true;
char auth[] = "545db7988e09468da8bae2506b99bc25";
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
bridge1.virtualWrite(V20, t);
bridge1.virtualWrite(V21, h);
BLYNK_CONNECTED()
bridge1.setAuthToken("473457fa470c42edb5c6c340661e2019");
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH);
Blynk.begin(auth);
dht.begin();
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(8, OUTPUT);
pinMode(5, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(8, HIGH);
digitalWrite(5, HIGH);
digitalWrite(7, HIGH);
digitalWrite(6, HIGH);
digitalWrite(9, HIGH);
BLYNK_WRITE(V9)
if (param.asInt() == 0)
digitalWrite(5, LOW);
BLYNK_WRITE(V15)
digitalWrite(6, LOW);
BLYNK_WRITE(V7)
digitalWrite(7, LOW);
BLYNK_WRITE(V8)
digitalWrite(8, LOW);
BLYNK_WRITE(V10)
digitalWrite(9, LOW);
BLYNK_WRITE(V11)
delay(500);
delay(500);
delay(500);
delay(500);
delay(2000);
delay(500);
delay(500);
delay(500);
delay(500);
delay(2000);
BLYNK_WRITE(V12)
delay(500);
delay(500);
delay(500);
delay(500);
delay(2000);
delay(500);
delay(500);
delay(500);
delay(500);
delay(2000);
