Problems using TFT ILI9341 together with a Time Input - Blynk Disconnects
Hardware: Arduino MEGA + noneMCU + ILI9341 TFT
iOS App with Blynk Cloud ; Libary 0.6.1
Hi Community,
unfortunately i have a problem with my project to integrate a display into my environment. My sketch works without the display without problems. But if I integrate the display , it works in principle. But if I use my automatic (BlynkTimer “activetoday”) based on time input (function V34 + alldays = 1) the display stops as soon as the function starts & Blynk loses its connection (and reboot i my case i try to remove the reboot before with the same result but without reboot) . If I set alldays to 0 everything works as it should Blynk stays connected&active and the display shows its text regularly. If i use my sketch without the the lcd_date timer active is works fine.
does anyone have an idea what I am doing wrong?
Thx for your help so far, i get stock on this behavior for days now ;(
Best
Hagi
// #define BLYNK_DEBUG
#include <ESP8266_Lib.h>
#include <Blynk.h>
#include <DHT.h>
#include <Wire.h>
#include "cactus_io_BME280_I2C.h"
#include <Adafruit_CCS811.h>
#include <WidgetRTC.h>
#include <TimeLib.h>
#include <avr/wdt.h>
// Display ILI9341
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_DC A10
#define TFT_CS A8
#define TFT_MOSI 51
#define TFT_CLK 52
#define TFT_RST A9
#define TFT_MISO 50
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
//define some colour values
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_CCS811 ccs;
BME280_I2C bme; // I2C using address 0x76
WidgetRTC rtc;
WidgetTerminal terminal(V1);
// You should get Auth Token in the Blynka App.
char auth[] = "*******";
char ssid[] = "****";
char pass[] = "****";
WidgetLED ledLicht(V46);
WidgetLED ledVentilator(V47);
WidgetLED ledLuefter(V48);
WidgetLED ledTest(V2);
bool ledStatus = false;
#define BLYNK_GREEN     "#23C48E"
#define BLYNK_BLUE      "#04C0F8"
#define BLYNK_YELLOW    "#ED9D00"
#define BLYNK_RED       "#D3435C"
#define BLYNK_DARK_BLUE "#5F7CD8"
#define EspSerial Serial3
#define led 32
#define onboardLed 13
#define ventilator 35
#define luefterLow 33
#define luefterHigh 34
#define DHTPIN A11
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
char Date[16];
char Time[16];
int t;
int h;
int t_a;
int h_a;
int t_i;
int h_i;
int maxTemp = 30;
int maxH = 65;
char currentTime[9];
bool clockSync = false;
bool notifiedT     = false;
bool notifiedH     = false;
int alldays ;
int manual = 0;
long startsecondswd;            // weekday start time in seconds
long stopsecondswd;             // weekday stop  time in seconds
long nowseconds;                // time now in seconds
bool isFirstConnect = true;
// Calibration for Soil Sensors
const int AirValue1 = 595;
const int WaterValue1 = 300;
const int AirValue2 = 580;
const int WaterValue2 = 293;
const int AirValue3 = 586;
const int WaterValue3 = 290;
const int AirValue4 = 590;
const int WaterValue4 = 290;
int soil_sensor1 = A1;
int output_value1 ;
int moisturelevel1;
int soil_sensor2 = A2;
int output_value2 ;
int moisturelevel2 ;
int soil_sensor3 = A3;
int output_value3 ;
int moisturelevel3 ;
int soil_sensor4 = A7;
int output_value4 ;
int moisturelevel4 ;
int co2_ppm ;
int TVOC;
int ledPin = 32;
int ventilatorPin = 35;
int luefterLowPin = 33;
int luefterHighPin = 34;
  dht.begin();
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  pinMode(onboardLed, OUTPUT);
  digitalWrite(onboardLed, LOW);
  pinMode(ventilatorPin, OUTPUT);
  digitalWrite(ventilatorPin, HIGH);
  pinMode(luefterLowPin, OUTPUT);
  digitalWrite(luefterLowPin, HIGH);
  pinMode(luefterHighPin, OUTPUT);
  digitalWrite(luefterHigh, HIGH);
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  setSyncInterval(10 * 60); // RTC Sync interval in seconds (10 minutes)
  // Clear the terminal content
  terminal.clear();
  // Start Display
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9341_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Blynk.virtualWrite(V1,"Blynk v ", BLYNK_VERSION, ": Sync gestartet\n");
  Blynk.virtualWrite(V1,"-------------\n");
  Blynk.syncVirtual(V33, V35, V36);
  delay(20);
  Blynk.syncVirtual(V15, V16);
  terminal.flush();
  if (!ccs.begin()) {
    Serial.println("Start des co2-Sensors fehlgeschlagen! Bitte ueberpruefen Sie Ihre Verdrahtung.");
    terminal.println("Start des co2-Sensors fehlgeschlagen! Bitte ueberpruefen Sie Ihre Verdrahtung.");
    terminal.flush();
  if (!bme.begin()) {
  Serial.println("Es konnte kein BME280 Sensor gefunden werden!");
  Serial.println("Bitte überprüfen Sie die Verkabelung!");
  // while (1);
  bme.setTempCal(-1);
  timer.setInterval(100000L, checkBlynk);
  timer.setInterval(14000L, clockDisplay);
  timer.setInterval(31000L, sendSensor);
  timer.setInterval(60000L, activetoday);
  timer.setInterval(10000L, lcd_data);
  ledLicht.on();
  ledLicht.setColor(BLYNK_RED);
  ledVentilator.on();
  ledVentilator.setColor(BLYNK_RED);
  ledLuefter.on();
  ledLuefter.setColor(BLYNK_RED);
  ledTest.on();
  ledTest.setColor(BLYNK_RED);
void resetNotifiedT()
  notifiedT = 0;
void resetNotifiedH()
  notifiedH = 0;
void checkBlynk() {
  if (!Blynk.connected()) {
    Serial.println();
    Serial.println("*********** Verbindungs Fehler ************");
    Serial.println("Nicht mit dem Blynk-Server verbunden");
    Serial.println("*********** Automatischer Neustart ************");
    Serial.println();
    wdt_enable(WDTO_1S);
BLYNK_CONNECTED() {
  rtc.begin();
void activetoday() {
  if (alldays == 1) {
    Blynk.syncVirtual(V34);
void clockDisplay() { // only needs to be done once after time sync
  if ((year() != 1970) && (clockSync == false)) {
    sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
    Serial.println(currentTime);
    // terminal.println(currentTime);
    clockSync = true;
  int gmthour = hour();
  if (gmthour == 24) {
    gmthour = 0;
  String displayhour =   String(gmthour, DEC);
  int hourdigits = displayhour.length();
  if (hourdigits == 1) {
    displayhour = "0" + displayhour;
  String displayminute = String(minute(), DEC);
  int minutedigits = displayminute.length();
  if (minutedigits == 1) {
    displayminute = "0" + displayminute;
BLYNK_WRITE(V15)
maxTemp = param.asInt();
BLYNK_WRITE(V16)
maxH = param.asInt();
BLYNK_WRITE(V33) {
  switch (param.asInt())
    case 1: // Item 1
      alldays = 1;
      terminal.println("Automatik Beleuchtung: Auto");
      break;
    case 2: // Item 2
      alldays = 0;
      terminal.println("Automatik Beleuchtung: Manuell Aus");
      break;
    case 3:
      alldays = 0;
      digitalWrite(ledPin, LOW); // set LED OFF
      ledLicht.setColor(BLYNK_GREEN);
      terminal.println("Automatik Beleuchtung: Manuell An");
      break;
    default:
      alldays = 1;
  // Serial.println("DEBUG: V33 OK");
  terminal.flush();
BLYNK_WRITE(V34)//All days
  if (alldays == 1) {
    sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());
    TimeInputParam t(param);
    terminal.print("Check Automatik Beleuchtung gestartet: ");
    terminal.println(Time);
    terminal.flush();
    int dayadjustment = -1;
    if (weekday() == 1) {
      dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
    if (t.isWeekdaySelected(weekday() + dayadjustment)) { //Time library starts week on Sunday, Blynk on Monday
      terminal.println("Automatik aktiv heute");
      terminal.flush();
      if (t.hasStartTime()) // Process start time
        terminal.println(String("Starte Nachtphase: ") + t.getStartHour() + ":" + t.getStartMinute());
        terminal.flush();
      if (t.hasStopTime()) // Process stop time
        terminal.println(String("Stop Nachtphase : ") + t.getStopHour() + ":" + t.getStopMinute());
        terminal.flush();
      // Display timezone details, for information purposes only
      terminal.println(String("Zeitzone: ") + t.getTZ()); // Timezone is already added to start/stop time
      //  terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
      terminal.flush();
      for (int i = 1; i <= 7; i++) {  // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
        if (t.isWeekdaySelected(i)) {
          // terminal.println(String("Tag ") + i + " ist ausgewaehlt");
          // terminal.flush();
      nowseconds = ((hour() * 3600L) + (minute() * 60L) + second());
      // terminal.println(String("hour : ") + (hour() * 3600L) );
      // terminal.println(String("minute : ") + (minute() * 60L));
      // terminal.println(String("second : ") + second());
      // terminal.println((hour() * 3600L) + (minute() * 60) + second());
      startsecondswd = (t.getStartHour() * 3600L) + (t.getStartMinute() * 60L);
      // terminal.println(String("DEBUG : nowseconds : ") + nowseconds);
      // terminal.println(String("DEBUG : Startpsecondswd : ") + startsecondswd); // used for debugging
      terminal.flush();
      if (nowseconds >= startsecondswd) {
        terminal.print("LED aus ab");
        terminal.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
        terminal.flush();
        if (nowseconds <= startsecondswd + 90) {  // 90s on 60s timer ensures 1 trigger command is sent
          terminal.print("LED Bechleuchtung ist ausgeschalten. Es ist Nacht !");
          // set LED ON
          // Blynk.virtualWrite(V2, 1);
          // code here to switch the relay ON
      else {
        terminal.println("LED Bechleutung eingeschalten. Es ist Tag.");
        terminal.flush();
      stopsecondswd = (t.getStopHour() * 3600L) + (t.getStopMinute() * 60L);
      // terminal.println(String("DEBUG : Stopsecondswd : ") + stopsecondswd);  // used for debugging
      if (nowseconds >= stopsecondswd) {
        terminal.print("LED an ab");
        terminal.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
        terminal.flush();
        if (nowseconds <= stopsecondswd + 90) { // 90s on 60s timer ensures 1 trigger command is sent
          // code here to switch the relay OFF
      else {
          terminal.print("LED Bechleuchtung ist ausgeschaltet. Es ist Nacht !");
          terminal.flush();
    else {
      terminal.println("Automatik heute nicht aktiv.");
      terminal.flush();
    terminal.println();
BLYNK_WRITE(V35) {
    case 1:
      terminal.println("Umluftventilator Aus");
      break;
    case 2:
      terminal.println("Umluftventilator An");
      digitalWrite(ventilatorPin, LOW);
      ledVentilator.setColor(BLYNK_GREEN);
      break;
    default:
  terminal.flush();
BLYNK_WRITE(V36) {
    case 1:
      terminal.println("Abluftventilator Aus");
      digitalWrite(luefterHighPin, HIGH);
      break;
    case 2:
      terminal.println("Abluftventilator 80%");
      digitalWrite(luefterLowPin, LOW);
      ledLuefter.setColor(BLYNK_BLUE);
      break;
    case 3:
      terminal.println("Abluftventilator 100%");
      digitalWrite(luefterHighPin, LOW);
      ledLuefter.setColor(BLYNK_DARK_BLUE);
      break;
    default:
  terminal.flush();
BLYNK_WRITE(V1)
  if (String("Marco") == param.asStr()) {
    terminal.println("You said: 'Marco'") ;
    terminal.println("I said: 'Polo'") ;
    // Send it back
    terminal.print("You said:");
    terminal.write(param.getBuffer(), param.getLength());
    terminal.println();
  terminal.flush();
void lcd_data ()
  testText();
unsigned long testText() {
  tft.fillScreen(ILI9341_BLACK);
  unsigned long start = micros();
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(ILI9341_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(ILI9341_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
void sendSensor()
  String notifyStringT;
  String notifyStringH;
  bme.readSensor();
  h_a = dht.readHumidity();
  t_a = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  h_i = bme.getHumidity();
  t_i = bme.getTemperature_C(); // or dht.readTemperature(true) for Fahrenheit
  output_value1 = analogRead(soil_sensor1);
  moisturelevel1 = constrain ( map(output_value1, AirValue1, WaterValue1, 0, 100), 0, 100);
  output_value2 = analogRead(soil_sensor2);
  moisturelevel2 = constrain ( map(output_value2, AirValue2, WaterValue2, 0, 100), 0, 100);
  output_value3 = analogRead(soil_sensor3);
  moisturelevel3 = constrain ( map(output_value3, AirValue3, WaterValue3, 0, 100), 0, 100);
  output_value4 = analogRead(soil_sensor4);
  moisturelevel4 = constrain (map(output_value4, AirValue4, WaterValue4, 0, 100), 0, 100);
  if (ccs.available()) {
    if (!ccs.readData()) {
      ccs.setDriveMode(4);
      ccs.readData();
      co2_ppm = (ccs.geteCO2());
      TVOC = (ccs.getTVOC());
    else {
      terminal.println("CO2-Sensor - FEHLER!");
      ccs.readData();
 if (t_i >= maxTemp && !notifiedT)
      notifiedT = true;
      notifyStringT = "Alarm - Temperatur IST:" + String(t_i) + " SOLL MAX:" + String(maxTemp);
      Serial.println(notifyStringT);
      terminal.println(notifyStringT);
      Blynk.notify(notifyStringT);
      timer.setTimeout(600000L, resetNotifiedT);
  if (h_i >= maxH && !notifiedH)
      notifiedH = true;
      notifyStringH = "Alarm - Luftfeuchtigkeit IST:" + String(h_i) + " SOLL MAX:" + String(maxH);
      Serial.println(notifyStringH);
      terminal.println(notifyStringH);
      Blynk.notify(notifyStringH);
      timer.setTimeout(600000L, resetNotifiedH);
  Blynk.virtualWrite(V5, h_i);
  Blynk.virtualWrite(V6, t_i);
  Blynk.virtualWrite(V13, h_a);
  Blynk.virtualWrite(V14, t_a);
  Blynk.virtualWrite(V7, moisturelevel1 );
  Blynk.virtualWrite(V8, moisturelevel2 );
  Blynk.virtualWrite(V9, moisturelevel3 );
  Blynk.virtualWrite(V10, moisturelevel4 );
  Blynk.virtualWrite(V21, output_value1 );
  Blynk.virtualWrite(V22, output_value2 );
  Blynk.virtualWrite(V23, output_value3 );
  Blynk.virtualWrite(V24, output_value4 );
  // 400ppm - 8192ppm
  Blynk.virtualWrite(V11, co2_ppm);
  // 0ppb- 1187ppb
  Blynk.virtualWrite(V12, TVOC);
  terminal.flush();
11:50:40.601 -> [0]
11:50:40.601 ->     ___  __          __
11:50:40.601 ->    / _ )/ /_ _____  / /__
11:50:40.601 ->   / _  / / // / _ \/  '_/
11:50:40.635 ->  /____/_/\_, /_//_/_/\_\
11:50:40.635 ->         /___/ v0.6.1 on Arduino Mega
11:50:40.635 ->
11:50:40.635 -> [7] Con2:WiFi
11:50:47.202 -> [6582] AT version:1.3.0.0(Jul 14 2016 18:54:01)
11:50:47.202 -> SDK version:2.0.0(5a875ba)
11:50:47.202 -> v1.0.0.3
11:50:47.202 -> Mar 13 2018 09:37:06
11:50:47.202 -> OK
11:50:52.777 -> [12150] IP = +CIPSTA:ip:"192.168.1.56"
11:50:52.777 -> +CIPSTA:gateway:"192.168.1.1"
11:50:52.777 -> +CIPSTA:netmask:"255.255.255.0"
11:50:52.777 -> [12154] WOK
11:51:02.902 -> [22287] Ready (ping: 12ms).
11:51:03.253 -> [22637] Time sync: OK
11:51:04.101 -> Display Power Mode: 0x94
11:51:04.101 -> MADCTL Mode: 0x48
11:51:04.101 -> Pixel Format: 0x5
11:51:04.101 -> Image Format: 0x80
11:51:04.101 -> Self Diagnostic: 0xC0
11:51:23.840 -> 11:51:23
11:52:50.331 ->
11:52:50.331 -> *********** Verbindungs Fehler ************
11:52:50.331 -> Nicht mit dem Blynk-Server verbunden
11:52:50.331 -> *********** Automatischer Neustart ************
