BLYNK
BLYNK.IO       šŸ“² GETTING STARTED       šŸ“— DOCS       šŸ‘‰ SKETCH BUILDER
Problems using DS18B20 waterproof temperature sensor with Blynk
Hi
I am using a DS18B20 waterproof temperature sensor in my project. I am also using other sensors which work fine with blynk but the temperature sensor wont seem to work. When i run the below code the serial monitor shows that it is connected to blynk but it wont run the getTemperature command every 5 seconds. Is there anyone who has used this sensor with Blynk before? I am using an Arduino Uno rev3 board with an ESP8266 wifi shield.
#define BLYNK_TEMPLATE_ID           "TMPL7mLWZCzi"
#define BLYNK_DEVICE_NAME           "Quickstart Device"
#define BLYNK_AUTH_TOKEN            "SQKj9qqAVwTsrLHimtkkdvSPMFuj8Ss_"
#include <ESP8266_Lib.h>
char ssid[] = "Tenda_3165"; //"VODAFONE-6360";     //"Tenda_3165";
char pass[] = "JDwRadYk"; //"tYsx6nsxx946KAKf";     //"JDwRadYk";
//#define EspSerial Serial
SoftwareSerial EspSerial(2,3); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#include <OneWire.h>
#define ONE_WIRE_BUS 9
 float Celcius=0;
int DesiredTemperature = 25;
BLYNK_WRITE(V1)
  DesiredTemperature = param.asInt();
void getTemperature()
  Celcius=sensors.getTempCByIndex(0);
  Serial.print(" C  ");
  Serial.println(Celcius);
   Serial.print("Desired Temp ");
  Serial.println(DesiredTemperature);
  sensors.begin();
  // Set ESP8266 baud rate
  Blynk.begin(BLYNK_AUTH_TOKEN,wifi, ssid, pass);
  timer.setInterval(5000L, getTemperature);
Have you tried the same sketch without the Blynk.begin and Blynk.run commands to prove that communication with the sensor is working as expected?
How are you powering your ESP-01 and your sensor?
Hi Pete,
Yes i have tried that and they work.
I have done research and found that other people are having trouble using the Wire library and Blynk together. My code works perfectly with other sensors that don’t use the wire library. I don’t know if you have found this problem before?
No, I haven’t.
Have you tried to access the ā€˜getTemperature’ routine outside of the ā€˜timer’ routine.
In uPython I found that the issue with calling Blynk management routines with the Wi-Fi on cause no/false triggers and issues in some cases, something to do with the ā€œprioritiesā€ within the ESP devices, test it in the following way first to see if this is the case:
  1. Disable all Wi-Fi connections, so run it as a basic microcontroller
  2. Run your routine and see if you getting the temperature readings
  3. if this is the case, suggested work around below
create a Timer Flag and then check the flag and use the ā€˜getTemperature’ when it is set.
example:
int TempFlag = 0
void manageTemperature
     TempFlag = 1;
// then place this in your code
if TempFlag ==1
    getTemperature()
