Why do I have a button after I press and the board immediately disconnects?
Which button’s are you speaking about? Is it the configuration button? If yes, it is provided to fill in your wifi credentials to connect your device to your wifi.
If you can explain your problems better we can help you out.
I have 2 relays they are connected to d5 and d6 in the blink it is 1 and 2 virtual pin when I press the virtual button in the blink the board is disconnected from the blink
help please
Please post your code here properly formatted with triple backticks which looks like - “ ``` “
At the start and ending of the code.
EDIT: it may also be a power supply issue. Tell us what hardware you are using and how it is all wired up.
@Ruslan_Machuzhak i’m closing this topic, because you haven’t supplied any useful information.
Please create a new “need help with my project” topic, and this time provide ALL of the information that is requested when you create the topic, plus information about which version of Blynk you are using (0.1/Legacy or New/IoT) along with information about what is shown in your serial monitor when your device boots, connects, then disconnects.
