Problems regarding simple timer
**** #include <SimpleTimer.h>
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social networks: http://www.fb.com/blynkapp
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example shows how to use ESP8266 Shield (with AT commands)
  • to connect your project to Blynk.
  • WARNING!
  • It’s rather tricky to get it working, please read this article:
  • https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
  • Change WiFi ssid, pass, and Blynk auth token to run :slight_smile:
  • Feel free to apply it to any other example. It’s simple!
#include <ESP8266_Lib.h>
#include<Servo.h>
char auth[] = “auth”;
// Set password to “” for open networks.
char ssid[] = “Dreamerz”;
char pass[] = “pass”;
// Hardware Serial on Mega, Leonardo, Micro…
#define EspSerial Serial
Servo servo;
// or Software Serial on Uno, Nano…
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
BLYNK_WRITE(V1) {
if ( param.asInt()== 1 ) {
void enable(timer);
digitalWrite(18, HIGH);
servo.write(255);
??? //replace this with a function that can execute the following after 2 seconds
digitalWrite(18, LOW);
BLYNK_WRITE(V1)
{ if ( param.asInt() == 0 ) {
void enable(timer);
servo.write(10);
pinMode(18,OUTPUT);
timer.setTimeout(2000, repeatMe);
// Set console baud rate
// Set ESP8266 baud rate
void loop(){
help please. not able to understand simple timer
@Costas @Jamin
@Jamin please help me. i am no able to understand the SimpleTimer Library
