I am trying to convert a remotexy sketch to blynk which is badly readable, so I didnt want to make it a hassle here on the board.
actually this is the code i need to convert:
/*// -- Jacuzzi -- // version 6 avec
gestion améliorée des états invalides des leds
yield() function pour éviter les freeze (enfin je pense que cela y contribue)
Pour Jacuzzi SSP-H-20.1 Bubble only
R6.2.1 : avec fonction delay sur lecture segment et suppression clignotement
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP8266_SOFTSERIAL_CLOUD
// activate debug output on Serial 115200; ESP on SW Serial
#define REMOTEXY__DEBUGLOGS Serial
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 3
#define REMOTEXY_SERIAL_TX 2
#define REMOTEXY_SERIAL_SPEED 9600
#define REMOTEXY_WIFI_SSID "<<SSID>>"
#define REMOTEXY_WIFI_PASSWORD "<<PASS>>"
#define REMOTEXY_CLOUD_SERVER "cloud.remotexy.com"
#define REMOTEXY_CLOUD_PORT 6376
#define REMOTEXY_CLOUD_TOKEN "<<TOKEN>>"
// "THE REMOTE XY TOKEN See www.remotexy.com/en/account/tokens/"
// RemoteXY App configuration
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,5,0,25,0,217,0,8,8,1,
130,2,5,4,53,19,46,129,0,2,
39,12,5,16,70,105,108,116,101,114,
<DELETED SOME NUMBERS>
194,176,99,0,129,0,54,99,6,3,
17,82,54,46,50,0 };
// this structure defines all the variables of the control interface for the RemoteXY App
struct {
// input variable
uint8_t bpPower; // =1 if button pressed, else =0
uint8_t bpFilter; // =1 if button pressed, else =0
uint8_t bpHeater; // =1 if button pressed, else =0
uint8_t bpUp; // =1 if button pressed, else =0
uint8_t bpDown; // =1 if button pressed, else =0
// output variable
uint8_t ledPower_r; // =0..255 LED Red brightness
uint8_t ledPower_g; // =0..255 LED Green brightness
uint8_t ledFilter_r; // =0..255 LED Red brightness
uint8_t ledFilter_g; // =0..255 LED Green brightness
uint8_t ledHeater_r; // =0..255 LED Red brightness
uint8_t ledHeater_g; // =0..255 LED Green brightness
char digit1[2]; // string UTF8 end zero
char digit2[2]; // string UTF8 end zero
char digit3[2]; // string UTF8 end zero
char digit4[2]; // string UTF8 end zero
char waterTemp[11]; // string UTF8 end zero
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
// define I/O
#define SEGA 8 // actif LOW : état segment a également jetLed
#define SEGB 16 // actif LOW : état segment b également heater2Led
#define SEGC 17 // actif LOW : état segment c également sunheatPos
#define SEGD 9 // actif LOW : état segment d également set1Led
#define SEGE 10 // actif LOW : état segment e également filterLed
#define SEGF 11 // actif LOW : état segment f également heater1Led
#define SEGG 7 // actif LOW : état segment g
#define SEGDP 12 // actif LOW : état segment dp également set2Led
#define AFF1 A4 // actif LOW : Données afficheur digit 1 disponibles
#define AFF2 A1 // actif LOW : Données afficheur digit 2 disponibles
#define AFF3 A0 // actif LOW : Données afficheur digit 3 disponibles
#define AFF4 A5 // actif LOW : Données afficheur digit 4 disponibles
#define LEDS 13 // actif LOW : Données des autres LED's disponibles
#define LEDPOWER A7 // lecture d'un état on/off via Analog input car plus de digital input disponible
#define C4051 4 // D4 D5 et D6 utilisées en OUTPUT pour codage de 7 Commandes (+ 1 état neutre)...
#define B4051 5 // ....via 3 sorties et multiplexeur-interrupteur analogique CD4051
#define A4051 6 // CD4051 : C = pin 9; B= pin 10; A = pin 11
// déclaration des valeurs lues sur les I/O
boolean a,b,c,d,e,f,g,dp,h; // lecture de l'état des segments digits
boolean cdeAff1,cdeAff2,cdeAff3,cdeAff4,cdeLeds; // lecture du digit pour lequel les infos sont transmises
int powerLed; //lecture valeur analogique
boolean heater1Led,heater2Led,filterLed,jetLed; //bubbleLed non utilisée par manque d'entrées sur Nano
// déclaration et initialisation de variables
char digit[2];
int adigit=0,adigit1=0,adigit2=0,adigit3=0;
String digitseg="";
String digitsegled="11111111";
float tempWater=20.0;
int delayReadSeg=15;
// déclaration divers compteurs
int i=0;
int j=0;
int k1=0;
int k2=0;
int l=0;
int m=0;
int n=0;
int o=0;
int p=0;
int q=0;
int r=0;
int s=0;
int imax=1000; // nombre max d'itérations de lecture des bits de données afficheurs et états leds
int jmax=5; // autre compteur de base utilisé à divers endroits
// To replace the delay function (lets other routines working)
unsigned long currentMillis ;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
unsigned long previousMillis4 = 0;
const long interval1 = 250; // interval at which to repeat (delay in milliseconds)
const long interval2 = 5000;
const long interval3 = 10000;
const long interval4 = 20000;
RemoteXY_Init ();
// 115200 mendatory for debug
analogReference(INTERNAL);
// affectation des modes aux I/O Arduino; (pas de déclaration pour les entrées analogiques car pas d'alternative)
pinMode(SEGA,INPUT); // voir également les autres affectations de ces entrées dans la fonction Void lecture digit ci-dessous
pinMode(SEGB,INPUT);
pinMode(SEGC,INPUT);
pinMode(SEGD,INPUT);
pinMode(SEGE,INPUT);
pinMode(SEGF,INPUT);
pinMode(SEGG,INPUT);
pinMode(SEGDP,INPUT);
pinMode(AFF1,INPUT);
pinMode(AFF2,INPUT);
pinMode(AFF3,INPUT);
pinMode(AFF4,INPUT);
pinMode(LEDS,INPUT);
// No need to define A7 (powerLed) because INPUT only
pinMode(C4051,OUTPUT); // 3 Sorties vers CD 4051 positionnées à 1
pinMode(B4051,OUTPUT);
pinMode(A4051,OUTPUT);
digitalWrite(C4051,1);
digitalWrite(B4051,1);
digitalWrite(A4051,1);
// initialisation des variables à la valeur 1 car le circuit fonctionne en logique inversée
a=1,b=1,c=1,d=1,e=1,f=1,g=1,dp=1;
cdeAff1=1,cdeAff2=1,cdeAff3=1,cdeAff4=1,cdeLeds=1;
powerLed=1023;
heater1Led=1,heater2Led=1,filterLed=1;
// affichage par défaut au lancement
RemoteXY.ledPower_r=0;RemoteXY.ledPower_g=0;
RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=0;
RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=0;
digit[0]='0';
strcpy (RemoteXY.digit1, digit);
strcpy (RemoteXY.digit2, digit);
strcpy (RemoteXY.digit3, digit);
digit[0]='c';
strcpy (RemoteXY.digit4, digit);
dtostrf(tempWater, 0, 0, RemoteXY.waterTemp);
RemoteXY_Handler();
// acquisition des valeurs introduites via l'app : delais de lecture des segments après flanc descendant
// du bit de données afficheurs ou led's et nombre max d'itérations de lecture de ces bits
// gestion des commandes en provenance RemoteXY via BCD vers 1 de 10 (en réalité 1 de 8) (Mux analogique CD4051)
// gestion de la durée de l'impulsion de commande
currentMillis = millis();
if (currentMillis - previousMillis1 >= interval1) {
previousMillis1 = currentMillis;
if(RemoteXY.bpFilter!=0) {
digitalWrite(C4051,0);
digitalWrite(B4051,0);
digitalWrite(A4051,0); }
if(RemoteXY.bpUp!=0) {
previousMillis4 = millis(); // to freeze the update of tempWater when pushed
digitalWrite(A4051,1); }
if(RemoteXY.bpDown!=0) {
if(RemoteXY.bpPower!=0) {
if(RemoteXY.bpHeater!=0) {
lectureleds();
// lecture et décodage des digits
i=0;
cdeAff1=digitalRead(AFF1);
while (cdeAff1==1 && i<imax) {cdeAff1=digitalRead(AFF1);i++;yield();}
if (cdeAff1==0 && i<imax) {
delayMicroseconds(delayReadSeg);
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != 'c' && digit[0] != ' ') {
adigit1=adigit;
strcpy (RemoteXY.digit1, digit);}
i=0;
cdeAff2=digitalRead(AFF2);
while (cdeAff2==1 && i<imax) {cdeAff2=digitalRead(AFF2);i++;yield();}
if (cdeAff2==0 && i<imax) {
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != 'c' && ((millis() - previousMillis4) <= (interval4/4)) ) { // ' ' value authorized when modifying temp instruction
adigit2=adigit;
strcpy (RemoteXY.digit2, digit);}
adigit2=adigit;
i=0;
cdeAff3=digitalRead(AFF3);
while (cdeAff3==1 && i<imax) {cdeAff3=digitalRead(AFF3);i++;yield();}
if (cdeAff3==0 && i<imax) {
lecturedigit();
decodage();
adigit3=adigit;
strcpy (RemoteXY.digit3, digit);}
adigit3=adigit;
i=0;
cdeAff4=digitalRead(AFF4);
while (cdeAff4==1 && i<imax ) {cdeAff4=digitalRead(AFF4);i++;yield();}
if (cdeAff4==0 && i<imax) {
lecturedigit();
decodage();
if (digit[0] != 'x' && digit[0] != ' ') {
strcpy (RemoteXY.digit4, digit);}
// affichage température de l'eau jacuzzi moyennant respect des conditions
if (digit[0]=='c' && adigit1==0 && (currentMillis - previousMillis4) >= interval4) {
// previousMillis4=currentMillis;
tempWater=(adigit3+(10*adigit2));
// si l'afficheur sur SPA est en °F, conversion en °c (tempSun et tempWater tjrs en °c)
if (digit[0]=='F' && (currentMillis - previousMillis4) >= interval4) {
tempWater=((adigit3+(10*adigit2)+(100*adigit1)-32)/1.8);
void lectureleds(){
// tests delay usec: de 10 à 200: c'est 15 usec qui donne mes meilleurs résultats (99% de réussite)
// détection platine sous tension (=> Led Rouge allumée) + lecture et décodage des led's d'état
// jmax changements consécutifs pour être pris en compte
i=0;
cdeLeds=digitalRead(LEDS);
while (cdeLeds==1 && i<imax){cdeLeds=digitalRead(LEDS);i++;yield();} // détection présence de bits états LED
if (cdeLeds==0 && i<imax){
powerLed=analogRead(LEDPOWER); // utilisation d'une entrée analogique pour lecture d'une valeur digitale suite manque d'entrées digitales
lecturedigit();
if(powerLed<=900){a=0;}
else{a=1;}
digitseg=String(String(a)+String(f)+String(b)+String(d)+String(dp)+String(e)+String(c));
s=0;
while(digitsegled!=digitseg && s<jmax){
i=0;s++;yield();
lecturedigit();
else{a=1;}
if(digitsegled!=digitseg){
digitsegled=digitseg;
heater1Led=f;heater2Led=b;filterLed=e;
if(powerLed<=900){RemoteXY.ledPower_r=255;RemoteXY.ledPower_g=0;}
else{RemoteXY.ledPower_r=0;RemoteXY.ledPower_g=0;}
if(heater2Led==0 && heater1Led==1){RemoteXY.ledHeater_r=255;RemoteXY.ledHeater_g=0;} // led rouge
if(heater2Led==1 && heater1Led==0){RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=255;} // led verte
if(heater2Led==1 && heater1Led==1){RemoteXY.ledHeater_r=0;RemoteXY.ledHeater_g=0;} // led éteinte
if(filterLed==0){RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=255;} // led verte
else{RemoteXY.ledFilter_r=0;RemoteXY.ledFilter_g=0;} // led éteinte
void decodage(){
// Actif LOW
digitseg=String(String(a)+String(b)+String(c)+String(d)+String(e)+String(f)+String(g));
digit[0]='x';
if (digitseg == "1111111") {digit[0]=' ';adigit=0;}
if (digitseg == "0000001") {digit[0]='0';adigit=0;}
if (digitseg == "1111001") {digit[0]='1';adigit=1;}
if (digitseg == "0010010") {digit[0]='2';adigit=2;}
if (digitseg == "0110000") {digit[0]='3';adigit=3;}
if (digitseg == "1101000") {digit[0]='4';adigit=4;}
if (digitseg == "0100100") {digit[0]='5';adigit=5;}
if (digitseg == "0000100") {digit[0]='6';adigit=6;}
if (digitseg == "1110001") {digit[0]='7';adigit=7;}
if (digitseg == "0000000") {digit[0]='8';adigit=8;}
if (digitseg == "0100000") {digit[0]='9';adigit=9;}
if (digitseg == "0000111") {digit[0]='c';adigit=10;}
if (digitseg == "1001000") {digit[0]='H';adigit=11;}
if (digitseg == "0000110") {digit[0]='E';adigit=12;}
if (digitseg == "1000110") {digit[0]='F';adigit=13;}
if (digitseg == "1011100") {digit[0]='n';adigit=14;}
if (digitseg == "0011000") {digit[0]='d';adigit=13;}
// Serial.print(digit[0]);
void lecturedigit(){
a=digitalRead(SEGA); // également jetLed
b=digitalRead(SEGB); // également heater2Led
c=digitalRead(SEGC);
d=digitalRead(SEGD);
e=digitalRead(SEGE); // également filterLed
f=digitalRead(SEGF); // également heater1Led
g=digitalRead(SEGG);
dp=digitalRead(SEGDP);
