Problem with the virtual PIN read
I have problelm with my project “Control speed motor”
This is my code
    #define IN1 D1
    char auth[] = "56VAm5a00DBEy_-KTX2rlLfBUAwj1ZFQ"; // Nhập AuthToken của bạn
    char ssid[] = "NhatDuong"; //
    char pass[] = "23456789"; // Nhập password WiFi
    int swith;
    int trl;
    int spe;
    BLYNK_CONNECTED() {
      Blynk.syncAll();
      BLYNK_WRITE(V0); {
        int swith = param.asInt();
            if(swith == 1); {
        BLYNK_WRITE(V1); {
       int trl = param.asInt();
        BLYNK_WRITE(V3); {
       int spe = param.asInt();
        analogWrite(IN1, (spe + trl)* 10 );
        else if (swith == 0); {
            analogWrite (IN1, 0) ;}
      pinMode(IN1, OUTPUT);
When I run the program, the following error message appears
Not used: C:\Users\DAI\Documents\Arduino\libraries\Blynk
exit status 1
'param' was not declared in this scope
I don’t understand this error and try to edit my code but it doesn’t work.
Pleas help me !
I don’t know where you got this kind of syntax from. It’s invalid.
Please follow examples provided with the blynk library.
Try this…
BLYNK_CONNECTED()
  Blynk.syncAll();
BLYNK_WRITE(V0)
  if(swith == 1)
    // do something in here, maybe this..
    // analogWrite (IN1, 1) ;
BLYNK_WRITE(V1)
  int trl = param.asInt();  // Note that trl is a LOCAL variable!
BLYNK_WRITE(V3)
  analogWrite(IN1, (spe + trl)* 10 ); // trl is local to BLYNK_WRITE(V1), so you'll get an error or an unexpected result
The way that you lay out your code makes a big difference to its readability. You also need to learn more about C++ syntax, and variable scope.
remove the semicolon
Thank you pro ! I will try your way again.
