Problem with quickstart
hello everyone, i am having a problem with quickstart. i am trying to connect my esp32-WROOM with blynk but it never comes online and it always shows waiting for device online. i tried with my iphone hotspot and also with my home wifi but it still shows offline. please help me!
Region- ny3
arduino ide version - 2.2.1
the code is copied exactly from tempelate.
What does your serial monitor show?
Hello Pete,
I tried connecting with a different hotspot and this is the serial monitor output
rst:0x1 (POWERON RESET), boot: 0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP: Oxee
elk drv: 0x00, g drv: 0x00, d drv: 0x00, cs0_drv: 0x00, hd_drv: 0x00, w_drv: 0x00
mode: DIO, clock div: 1
load: 0x3ff£0030, len: 1344
load: 0x40078000, len: 13964
load: 0x40080400, len: 3600
entry 0x400805f0
[23] Connecting to Aayush's iphone
And on the Blynk QuickStart it still shows the same waiting for device to be online. And code is copied exactly from the Blynk QuickStart template.
@vpatel256 Please edit your post, using the pencil icon at the bottom, and replace your screenshot with the text copied from your serial monitor, and add triple backticks at the beginning and end of your code so that it displays correctly.
I’m interested in seeing the serial output from the point when the device boots, displays the Blynk splash screen and then connects to WiFi and then begins attempting to connect to Blynk.
Hello Pete ,
I have edited it. Initially there was no output in serial monitor and then I pressed the En button on esp and then it showed the output.
Okay, so it’s not managing to connect to your iPhone’s hotspot.
Newer iPhones default to 5GHz WiFi for the hotspot, and ESPs require 2.4GHz.
I’d also avoid SSIDs that jnclude spaces and apostrophes.
