Problem with new spark's libray
I have an issue while using blynk’s library for spark. I open the example sparkcore.ino, and I get those errors when i compile:
In file included from blynk/BlynkSparkCore.h:16:0,
from blynk/BlynkSimpleSparkCore.h:14,
from sparkcore.cpp:18:
blynk/BlynkApiSparkCore.h:74:6: warning: #warning “analogInputToDigitalPin not defined => Named analog pins will not work” [-Wcpp]
In file included from blynk/BlynkSparkCore.h:17:0,
blynk/BlynkProtocol.h: In member function ‘int BlynkProtocol::readHeader(BlynkHeader&)’:
This looks like an error in blynk library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
blynk/BlynkProtocol.h:325:34: error: there are no arguments to ‘ntohs’ that depend on a template parameter, so a declaration of ‘ntohs’ must be available [-fpermissive]
hdr.msg_id = ntohs(hdr.msg_id);
blynk/BlynkProtocol.h:325:34: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
CREATE ISSUE
blynk/BlynkProtocol.h:326:34: error: there are no arguments to ‘ntohs’ that depend on a template parameter, so a declaration of ‘ntohs’ must be available [-fpermissive]
hdr.length = ntohs(hdr.length);
blynk/BlynkProtocol.h: In member function ‘void BlynkProtocol::sendCmd(uint8_t, uint16_t, const void*, size_t, const void*, size_t)’:
CREATE ISSUE
blynk/BlynkProtocol.h:357:27: error: there are no arguments to ‘htons’ that depend on a template parameter, so a declaration of ‘htons’ must be available [-fpermissive]
hdr->msg_id = htons(id);
CREATE ISSUE
blynk/BlynkProtocol.h:358:39: error: there are no arguments to ‘htons’ that depend on a template parameter, so a declaration of ‘htons’ must be available [-fpermissive]
hdr->length = htons(length+length2);
blynk/BlynkProtocol.h: In instantiation of ‘void BlynkProtocol::sendCmd(uint8_t, uint16_t, const void*, size_t, const void*, size_t) [with Transp = BlynkTransportSparkCore; uint8_t = unsigned char; uint16_t = short unsigned int; size_t = unsigned int]’:
blynk/WidgetBridge.h:30:78: required from here
CREATE ISSUE
blynk/BlynkProtocol.h:357:27: error: ‘htons’ was not declared in this scope
CREATE ISSUE
blynk/BlynkProtocol.h:358:39: error: ‘htons’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
blynk/BlynkProtocol.h:357:27: note: ‘htons’ declared here, later in the translation unit
blynk/BlynkProtocol.h: In instantiation of ‘int BlynkProtocol::readHeader(BlynkHeader&) [with Transp = BlynkTransportSparkCore]’:
blynk/BlynkProtocol.h:206:35: required from ‘bool BlynkProtocol::processInput() [with Transp = BlynkTransportSparkCore]’
blynk/BlynkProtocol.h:132:31: required from ‘bool BlynkProtocol::run(bool) [with Transp = BlynkTransportSparkCore]’
sparkcore.cpp:67:15: required from here
CREATE ISSUE
blynk/BlynkProtocol.h:325:34: error: ‘ntohs’ was not declared in this scope
CREATE ISSUE
blynk/BlynkProtocol.h:326:34: error: ‘ntohs’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
blynk/BlynkProtocol.h:325:34: note: ‘ntohs’ declared here, later in the translation unit
make[1]: *** […/build/target/user/platform-6sparkcore.o] Error 1
make: *** [user] Error 2
You have to make sure you’re using Blynk library v0.3.3 or later.
What hardware are you using? please be more specific.
Closed as a duplicate of Blynk Photon Library not loading
