Problem with Home Automation Project
Hi there, i have created this really simple code to send some useful data like temperature, humidity, soil moisture and gas quality to nodemcu via the internet. I am using gas sensor MQ2, soil moisture sensor and DHT11 sensor for temp and humidity. But unfortunately soil sensor and MQ2 is not sending any data. PLZ help ME!!
CODE-
    #include <DHT.h>
    char auth[] = "a9c89af929024044a8146779d7111aef";
    char ssid[] = "BHUTANI";
    char pass[] = "#198s6i8";
    #define DHTPIN 2          // What digital pin temperature and humidity sensor is connected to
    #define soilPin 0         // What digital pin soil moisture sensor is connected to
    #define gasPin 4          // What digital pin gas sensor is connected to
    #define DHTTYPE DHT11     // DHT 11
    DHT dht(DHTPIN, DHTTYPE);
    void sendSensor()
    float h = dht.readHumidity();
    if (isnan(h) || isnan(t)) {
    return;
    Blynk.virtualWrite(V5, h);
    Blynk.virtualWrite(V6, t);
    void sendsoilSensor()
    float s = analogRead(soilPin);
     if (isnan(s)) {
     Serial.println("Failed to read from Gas sensor!");
    return;
     Blynk.virtualWrite(V7, s);
     void sendgasSensor()
     float g = analogRead(gasPin);
     if (isnan(g)) {
    return;
     Blynk.virtualWrite(V8, g);
    dht.begin();
please, would you mind turning off the bold characters?
what esp board are you using?
nodemcu only have 1 analog port A1, so you are only able to read 1 analog value.
esp8266
and since when has the esp8266 2 analog pins?
How can i do it?
I thought GPIO pins can take analog data too!
You need to google “analogue multiplexer” if you want to find ways of using more than one analogue input with a NodeMCU/RSP8266.
Personally, I’d probably use multiple NodeMCU/ESP8266 devices with one analogue sensor per device. This approach might even make your setup simpler, if there is a physical distance between your gas, soil and humidity monitoring locations.
There is another way tell me if possible? I can use the analog pin for gas sensor and use a digital pin with soil sensor in order to just know if the soil is moist or nor!
You could use one of these:
actually, there are lots of modules even for gas and moisture sensors, which have also a digital output, and you can set the threshold level with a trimpot on the module. (like the one @PeteKnight linked)
thus, you can make the whole project using digital pins only. also, take care not to supply the gas sensors from digital pins, they consume ~150mA!
Why not to use an I2C ADC?
https://www.aliexpress.com/item/32819279709/32819279709.html
For example…
Thanks a lot! I have finally succeeded! I hooked the gas sensor to adc00 (A0) and digital pin of soil moisture sensor to a digital pin on nodemcu and it is finally working!
