Problem with coding
Hi
I use Blynk know than over a week and it’s amazing :smile: .
But if i put a delayMicroseconds(2); into my void loop() my “not virtual widgets” dont work anymore or react seconds later. Here is my project: I have a temperature-sensor, a hc-sr04 and a rgb-LED with three slider-widgets. But with the “delayMicroseconds(2);” everything works but not my rgb-LED (or it reacts seconds later). So all Digital-Widgets are interrupted by the “delayMicroseconds(2);” . [ 1, 2, 6 and 8 are virtual LED’s // V5 is the distance (hc-sr04) and V9 the temperature]
#define BLYNK_DEBUG // Optional, this enables lots of prints
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social groups: http://www.fb.com/blynkapp
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example shows how to use Arduino Ethernet shield (W5100)
  • to connect your project to Blynk.
  • Feel free to apply it to any other example. It’s simple!
#include <Ethernet.h>
char auth[] ="…";
int TMP = A0;
int temperature = 0;
int trigPin = 7;
int echoPin = 6;
Blynk.begin(auth);
// You can also specify server.
// For more options, see Transports/Advanced/CustomEthernet example
//Blynk.begin(auth, “server.org”, 8442);
//Blynk.begin(auth, IPAddress(…), 8888);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
long duration, distance;
digitalWrite(trigPin, LOW);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
distance = (duration/2) / 29.1;
Blynk.virtualWrite(5, distance);
temperature = map(analogRead(TMP), 0, 410, -50, 150);
Blynk.virtualWrite(9, temperature);
{ if (temperature >= 20)
Blynk.virtualWrite(1,HIGH);
Blynk.virtualWrite(1,LOW);
if (temperature < 20)
Blynk.virtualWrite(2,HIGH);
Blynk.virtualWrite(2,LOW);
{ if (distance >= 10)
Blynk.virtualWrite(8,HIGH);
Blynk.virtualWrite(8,LOW);
if (distance < 10)
Blynk.virtualWrite(6,HIGH);
Blynk.virtualWrite(6,LOW);
I hope you can help me with this ;).
I have added a simple 50 millisecond delay so I could blink an LED in the loop and it hasn’t affected the performance, however delays in your main loop may degrade the performance as stated in Blynk github page. I would maybe try something like: A very simple delayMicroseconds(2) routine and then slowly add more of the code in your loop and see when it breaks. Another thing is to add a timer. Here is one I use. Code:
#include <Bridge.h>
#include <BlynkSimpleYun.h>
#include <SimpleTimer.h>   //Good timer library
#include <dht.h>
#define dht_dpin 9
dht DHT;
int temp;
int humidity;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx";
  Blynk.begin(auth);
  // Setup function to be called every 2 seconds
  timer.setInterval(2000, sendData);
void sendData()
  DHT.read11(dht_dpin);
  temp = (DHT.temperature * 1.8 + 32);
  humidity = DHT.humidity;
  Blynk.virtualWrite(5, temp);
  Blynk.virtualWrite(6, humidity);
Also, if you highlight your code and then hit the </> button when writing your coment, it will format it better so we can read it easier.
