I already include all the pins in Blynk.Edgent File
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
#define USE_WROVER_BOARD
//#define USE_TTGO_T7
#include "BlynkEdgent.h"
#include <IRremote.h>
#define IR_RECV_PIN 35 // D35 (IR receiver pin)
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
#define RelayPin1 23 //D23
#define RelayPin2 22 //D22
#define RelayPin3 21 //D21
#define RelayPin4 19 //D19
#define SwitchPin1 13 //D13
#define SwitchPin2 12 //D12
#define SwitchPin3 14 //D14
#define SwitchPin4 27 //D27
#define wifiLed 2 //D2
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_C V9
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = LOW; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = LOW; //Define integer to remember the toggle state for relay 4
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
if(toggleState_1 == 1){
digitalWrite(RelayPin1, LOW);
else {
digitalWrite(RelayPin1, HIGH);
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
if(toggleState_2 == 1){
digitalWrite(RelayPin2, LOW);
else {
digitalWrite(RelayPin2, HIGH);
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
if(toggleState_3 == 1){
digitalWrite(RelayPin3, LOW);
else {
digitalWrite(RelayPin3, HIGH);
BLYNK_WRITE(VPIN_BUTTON_4) {
toggleState_4 = param.asInt();
if(toggleState_4 == 1){
digitalWrite(RelayPin4, LOW);
else {
digitalWrite(RelayPin4, HIGH);
BLYNK_WRITE(VPIN_BUTTON_C) {
all_SwitchOff();
void all_SwitchOff(){
toggleState_1 = 0; digitalWrite(RelayPin1, HIGH); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 0; digitalWrite(RelayPin2, HIGH); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 0; digitalWrite(RelayPin3, HIGH); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_4 = 0; digitalWrite(RelayPin4, HIGH); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
delay(100);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
irrecv.enableIRIn();
BlynkEdgent.begin();
manual_control(); //Manual Switch Control
ir_remote(); //IR remote Control
BlynkEdgent.run();
And the header file of blynkedgent.h
extern "C" {
void app_loop();
void eraseMcuConfig();
void restartMCU();
#include "Settings.h"
#include <BlynkSimpleEsp32_SSL.h>
#ifndef BLYNK_NEW_LIBRARY
#error "Old version of Blynk library is in use. Please replace it with the new one."
#endif
#if !defined(BLYNK_TEMPLATE_ID) || !defined(BLYNK_DEVICE_NAME)
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
#endif
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
#include "Console.h"
void manual_control();
void ir_remote();
inline
void BlynkState::set(State m) {
if (state != m && m < MODE_MAX_VALUE) {
DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
state = m;
// You can put your state handling here,
// i.e. implement custom indication
void printDeviceBanner()
Blynk.printBanner();
DEBUG_PRINT("--------------------------");
DEBUG_PRINT(String("Product: ") + BLYNK_DEVICE_NAME);
DEBUG_PRINT(String("Firmware: ") + BLYNK_FIRMWARE_VERSION " (build " __DATE__ " " __TIME__ ")");
if (configStore.getFlag(CONFIG_FLAG_VALID)) {
DEBUG_PRINT(String("Token: ...") + (configStore.cloudToken+28));
DEBUG_PRINT(String("Device: ") + BLYNK_INFO_DEVICE + " @ " + ESP.getCpuFreqMHz() + "MHz");
DEBUG_PRINT(String("MAC: ") + WiFi.macAddress());
DEBUG_PRINT(String("Flash: ") + ESP.getFlashChipSize() / 1024 + "K");
DEBUG_PRINT(String("ESP sdk: ") + ESP.getSdkVersion());
DEBUG_PRINT(String("Chip rev: ") + ESP.getChipRevision());
DEBUG_PRINT(String("Free mem: ") + ESP.getFreeHeap());
void runBlynkWithChecks() {
if (BlynkState::get() == MODE_RUNNING) {
if (!Blynk.connected()) {
if (WiFi.status() == WL_CONNECTED) {
BlynkState::set(MODE_CONNECTING_CLOUD);
BlynkState::set(MODE_CONNECTING_NET);
class Edgent {
public:
void begin()
WiFi.persistent(false);
WiFi.enableSTA(true); // Needed to get MAC
indicator_init();
button_init();
config_init();
console_init();
printDeviceBanner();
} else if (config_load_blnkopt()) {
DEBUG_PRINT("Firmware is preprovisioned");
BlynkState::set(MODE_WAIT_CONFIG);
void run() {
app_loop();
switch (BlynkState::get()) {
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: runBlynkWithChecks(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Edgent BlynkEdgent;
BlynkTimer edgentTimer;
void app_loop() {
edgentTimer.run();
edgentConsole.run();
manual_control();
ir_remote();
if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
Blynk.virtualWrite(VPIN_BUTTON_1, HIGH);
toggleState_1 = HIGH;
SwitchState_1 = HIGH;
Serial.println("Switch-1 on");
if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
Blynk.virtualWrite(VPIN_BUTTON_1, LOW);
SwitchState_1 = 0;
Serial.println("Switch-1 off");
if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
Blynk.virtualWrite(VPIN_BUTTON_2, HIGH);
toggleState_2 = HIGH;
SwitchState_2 = HIGH;
Serial.println("Switch-2 on");
if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
Blynk.virtualWrite(VPIN_BUTTON_2, LOW);
Serial.println("Switch-2 off");
if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
Blynk.virtualWrite(VPIN_BUTTON_3, HIGH);
toggleState_3 = HIGH;
SwitchState_3 = HIGH;
Serial.println("Switch-3 on");
if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
Blynk.virtualWrite(VPIN_BUTTON_3, LOW);
Serial.println("Switch-3 off");
if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
Blynk.virtualWrite(VPIN_BUTTON_4, HIGH);
toggleState_4 = HIGH;
SwitchState_4 = HIGH;
Serial.println("Switch-4 on");
if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
Blynk.virtualWrite(VPIN_BUTTON_4, LOW);
Serial.println("Switch-4 off");
void ir_remote(){
if (irrecv.decode(&results)) {
switch(results.value){
case 0x80BF49B6:
digitalWrite(RelayPin1, toggleState_1);
toggleState_1 = !toggleState_1;
delay(100);
break;
case 0x80BFC936:
digitalWrite(RelayPin2, toggleState_2);
toggleState_2 = !toggleState_2;
delay(100);
break;
case 0x80BF33CC:
digitalWrite(RelayPin3, toggleState_3);
toggleState_3 = !toggleState_3;
delay(100);
break;
case 0x80BF718E:
digitalWrite(RelayPin4, toggleState_4);
toggleState_4 = !toggleState_4;
delay(100);
break;
default : break;
//Serial.println(results.value, HEX);
irrecv.resume();
and ERROR
Arduino: 1.8.12 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
In file included from C:\Users\jamsa\OneDrive\Desktop\Edgent_ESP32_again_and_again\Edgent_ESP32_again_and_again.ino:17:0:
sketch\BlynkEdgent.h: In function 'void manual_control()':
BlynkEdgent.h:126:19: error: 'SwitchPin1' was not declared in this scope
BlynkEdgent.h:126:41: error: 'SwitchState_1' was not declared in this scope
BlynkEdgent.h:127:18: error: 'RelayPin1' was not declared in this scope
BlynkEdgent.h:128:24: error: 'VPIN_BUTTON_1' was not declared in this scope
BlynkEdgent.h:129:5: error: 'toggleState_1' was not declared in this scope
BlynkEdgent.h:133:19: error: 'SwitchPin1' was not declared in this scope
BlynkEdgent.h:133:42: error: 'SwitchState_1' was not declared in this scope
BlynkEdgent.h:134:18: error: 'RelayPin1' was not declared in this scope
BlynkEdgent.h:135:24: error: 'VPIN_BUTTON_1' was not declared in this scope
BlynkEdgent.h:136:5: error: 'toggleState_1' was not declared in this scope
BlynkEdgent.h:140:19: error: 'SwitchPin2' was not declared in this scope
BlynkEdgent.h:140:41: error: 'SwitchState_2' was not declared in this scope
BlynkEdgent.h:141:18: error: 'RelayPin2' was not declared in this scope
BlynkEdgent.h:142:24: error: 'VPIN_BUTTON_2' was not declared in this scope
BlynkEdgent.h:143:5: error: 'toggleState_2' was not declared in this scope
BlynkEdgent.h:147:19: error: 'SwitchPin2' was not declared in this scope
BlynkEdgent.h:147:42: error: 'SwitchState_2' was not declared in this scope
BlynkEdgent.h:148:18: error: 'RelayPin2' was not declared in this scope
BlynkEdgent.h:149:24: error: 'VPIN_BUTTON_2' was not declared in this scope
BlynkEdgent.h:150:5: error: 'toggleState_2' was not declared in this scope
BlynkEdgent.h:154:19: error: 'SwitchPin3' was not declared in this scope
BlynkEdgent.h:154:41: error: 'SwitchState_3' was not declared in this scope
BlynkEdgent.h:155:18: error: 'RelayPin3' was not declared in this scope
BlynkEdgent.h:156:24: error: 'VPIN_BUTTON_3' was not declared in this scope
BlynkEdgent.h:157:5: error: 'toggleState_3' was not declared in this scope
BlynkEdgent.h:161:19: error: 'SwitchPin3' was not declared in this scope
BlynkEdgent.h:161:42: error: 'SwitchState_3' was not declared in this scope
BlynkEdgent.h:162:18: error: 'RelayPin3' was not declared in this scope
BlynkEdgent.h:163:24: error: 'VPIN_BUTTON_3' was not declared in this scope
BlynkEdgent.h:164:5: error: 'toggleState_3' was not declared in this scope
BlynkEdgent.h:168:19: error: 'SwitchPin4' was not declared in this scope
BlynkEdgent.h:168:41: error: 'SwitchState_4' was not declared in this scope
BlynkEdgent.h:169:18: error: 'RelayPin4' was not declared in this scope
BlynkEdgent.h:170:24: error: 'VPIN_BUTTON_4' was not declared in this scope
BlynkEdgent.h:171:5: error: 'toggleState_4' was not declared in this scope
BlynkEdgent.h:175:19: error: 'SwitchPin4' was not declared in this scope
BlynkEdgent.h:175:42: error: 'SwitchState_4' was not declared in this scope
BlynkEdgent.h:176:18: error: 'RelayPin4' was not declared in this scope
BlynkEdgent.h:177:24: error: 'VPIN_BUTTON_4' was not declared in this scope
BlynkEdgent.h:178:5: error: 'toggleState_4' was not declared in this scope
sketch\BlynkEdgent.h: In function 'void ir_remote()':
BlynkEdgent.h:185:7: error: 'irrecv' was not declared in this scope
BlynkEdgent.h:185:22: error: 'results' was not declared in this scope
BlynkEdgent.h:188:26: error: 'RelayPin1' was not declared in this scope
BlynkEdgent.h:188:37: error: 'toggleState_1' was not declared in this scope
BlynkEdgent.h:190:32: error: 'VPIN_BUTTON_1' was not declared in this scope
BlynkEdgent.h:194:26: error: 'RelayPin2' was not declared in this scope
BlynkEdgent.h:194:37: error: 'toggleState_2' was not declared in this scope
BlynkEdgent.h:196:32: error: 'VPIN_BUTTON_2' was not declared in this scope
BlynkEdgent.h:200:26: error: 'RelayPin3' was not declared in this scope
BlynkEdgent.h:200:37: error: 'toggleState_3' was not declared in this scope
BlynkEdgent.h:202:32: error: 'VPIN_BUTTON_3' was not declared in this scope
BlynkEdgent.h:206:26: error: 'RelayPin4' was not declared in this scope
BlynkEdgent.h:206:37: error: 'toggleState_4' was not declared in this scope
BlynkEdgent.h:208:32: error: 'VPIN_BUTTON_4' was not declared in this scope
Multiple libraries were found for "IRremote.h"
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\IRremote
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Arduino-IRremote-master
Multiple libraries were found for "BlynkSimpleEsp32_SSL.h"
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Blynk
Not used: C:\Program Files (x86)\Arduino\libraries\Blynk
Multiple libraries were found for "WiFi.h"
Used: C:\Users\jamsa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3\libraries\WiFi
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\WiFiNINA
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
