Problem with Blynk.config
why this part say invalid token Blynk.config(auth, "***.***.***.***", 8442);
[11589] Connecting to 192.168.1.5:8442
[11696] Invalid auth token
[16689] Connecting to 192.168.1.5:8442
[16706] Invalid auth token
But this part connected to server Blynk.begin(auth, ssid, pass, IPAddress(***.***.***.***), 8442);
[10073] Connecting to 192.168.1.5
[10121] Ready (ping: 6ms).
  if(!Blynk.connected()){
      Blynk.connect();
Have you made a WiFi connection when you call the Blynk.config() function?
Presumably you wouldn’t get the invalid token message without WiFi, unless it’s hard coded in the library.
char ssid[] = "Blynk-Test";
char pass[] = "0000000000";
i’m so confused .
Me too :slight_smile:
Perhaps remove all your real code and post a full sketch to identify the problem.
@Costas
uh God!
  char auth[] = "*";
  Blynk.config(auth, "192.168.1.5", 8442);
  Blynk.connect();
  delay(500);
it’s work :joy::sweat_smile::hushed:
