Problem with BBC Micro Bit and Blink on Aduino IDE
I wanted to try to do the tutorial :
http://help.blynk.cc/en/articles/785447-bbc-micro-bit-arduino-ide
to configue the card.
I replaced my auth in the example but when I try to upload the programm, there is a error message :
“Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-10-10:13)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
swd
cortex_m reset_config sysresetreq
adapter speed: 1000 kHz
Error: nrf51.cpu – clearing lockup after double fault
Polling target nrf51.cpu failed, trying to reexamine
nrf51.cpu: target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0xc1000000 pc: 0x00018e20 msp: 0x20004000
** Programming Started **
auto erase enabled
wrote 35840 bytes from file C:\Users\flori\AppData\Local\Temp\arduino_build_659879/BBC_MicroBit.ino.hex in 3.193044s (10.961 KiB/s)
** Programming Finished **
** Verify Started **
verified 35592 bytes in 0.302084s (115.060 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked”
I don’t know what it is
I have :
  • Harware model + communication : BBC Micro Bit with Bluetooth
  • Smatphone Android
  • Softdevice : S110
  • Port COM4
  • Programmeur : CMSIS-DAP
  • and all requested librairies and support.
I just didn’t find that : Select: Tools -> nRF5 Flash SoftDevice (read and accept the license) but I think that I have already accept
Thank you in advance for your help
PS : I’m french
I am French so I apologize in advance for the mistakes
Difficile de répondre,il y a peu d’utilisateur de ce module.
