1MB flash sizee
sonoff header
1 - vcc 3v3
2 - rx
3 - tx
4 - gnd
5 - gpio 14
esp8266 connections
gpio 0 - button
gpio 12 - relay
gpio 13 - green led - active low
gpio 14 - pin 5 on header
#define SONOFF_BUTTON 0
#define SONOFF_INPUT 14
#define SONOFF_LED 5
#define SONOFF_AVAILABLE_CHANNELS 1
const int SONOFF_RELAY_PINS[4] = {12, 12, 12, 12};
//if this is false, led is used to signal startup state, then always on
//if it s true, it is used to signal startup state, then mirrors relay state
//S20 Smart Socket works better with it false
#define SONOFF_LED_RELAY_STATE false
#define HOSTNAME "sonoff"
//comment out to completly disable respective technology
#define INCLUDE_BLYNK_SUPPORT
#define INCLUDE_MQTT_SUPPORT
Should not need to edit below this line *
#ifdef INCLUDE_BLYNK_SUPPORT
static bool BLYNK_ENABLED = true;
#endif
#ifdef INCLUDE_MQTT_SUPPORT
#include <PubSubClient.h> //https://github.com/Imroy/pubsubclient
WiFiClient wclient;
PubSubClient mqttClient(wclient);
static bool MQTT_ENABLED = true;
int lastMQTTConnectionAttempt = 0;
#endif
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <EEPROM.h>
#define EEPROM_SALT 12667
typedef struct {
char bootState[4] = "off";
char blynkToken[33] = "";
char blynkServer[33] = "blynk-cloud.com";
char blynkPort[6] = "8442";
char mqttHostname[33] = "";
char mqttPort[6] = "1883";
char mqttClientID[24] = HOSTNAME;
char mqttTopic[33] = HOSTNAME;
int salt = EEPROM_SALT;
} WMSettings;
WMSettings settings;
#include <ArduinoOTA.h>
//for LED status
#include <Ticker.h>
Ticker ticker;
const int CMD_WAIT = 0;
const int CMD_BUTTON_CHANGE = 1;
int cmd = CMD_WAIT;
//int relayState = HIGH;
//inverted button state
int buttonState = HIGH;
static long startPress = 0;
//http://stackoverflow.com/questions/9072320/split-string-into-string-array
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = {0, -1};
int maxIndex = data.length()-1;
for(int i=0; i<=maxIndex && found<=index; i++){
if(data.charAt(i)==separator || i==maxIndex){
found++;
strIndex[0] = strIndex[1]+1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
void tick()
//toggle state
int state = digitalRead(SONOFF_LED); // get the current state of GPIO1 pin
digitalWrite(SONOFF_LED, !state); // set pin to the opposite state
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
//if you used auto generated SSID, print it
Serial.println(myWiFiManager->getConfigPortalSSID());
//entered config mode, make led toggle faster
ticker.attach(0.2, tick);
void updateBlynk(int channel) {
int state = digitalRead(SONOFF_RELAY_PINS[channel]);
Blynk.virtualWrite(channel * 5 + 4, state * 255);
#endif
void updateMQTT(int channel) {
char topic[50];
sprintf(topic, "%s/channel-%d/status", settings.mqttTopic, channel);
String stateString = state == 0 ? "off" : "on";
if ( channel >= SONOFF_AVAILABLE_CHANNELS) {
stateString = "disabled";
mqttClient.publish(topic, stateString);
#endif
void setState(int state, int channel) {
//relay
digitalWrite(SONOFF_RELAY_PINS[channel], state);
//led
if (SONOFF_LED_RELAY_STATE) {
digitalWrite(SONOFF_LED, (state + 1) % 2); // led is active low
//blynk
updateBlynk(channel);
//MQTT
updateMQTT(channel);
void turnOn(int channel = 0) {
setState(relayState, channel);
void turnOff(int channel = 0) {
int relayState = LOW;
void toggleState() {
cmd = CMD_BUTTON_CHANGE;
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void toggle(int channel = 0) {
Serial.println("toggle state");
Serial.println(digitalRead(SONOFF_RELAY_PINS[channel]));
int relayState = digitalRead(SONOFF_RELAY_PINS[channel]) == HIGH ? LOW : HIGH;
void restart() {
//TODO turn off relays before restarting
ESP.reset();
void reset() {
//reset settings to defaults
WMSettings defaults;
settings = defaults;
EEPROM.begin(512);
EEPROM.put(0, settings);
EEPROM.end();
//reset wifi credentials
WiFi.disconnect();
ESP.reset();
* VPIN % 5
* 0 off
* 1 on
* 2 toggle
* 3 value
* 4 led
BLYNK_WRITE_DEFAULT() {
int pin = request.pin;
int channel = pin / 5;
int action = pin % 5;
int a = param.asInt();
if (a != 0) {
switch(action) {
case 0:
turnOff(channel);
break;
case 1:
turnOn(channel);
break;
case 2:
toggle(channel);
break;
default:
Serial.print("unknown action");
Serial.print(action);
Serial.print(channel);
break;
BLYNK_READ_DEFAULT() {
// Generate random response
Blynk.virtualWrite(pin, digitalRead(SONOFF_RELAY_PINS[channel]));
//restart - button
BLYNK_WRITE(30) {
if (a != 0) {
restart();
//reset - button
BLYNK_WRITE(31) {
if (a != 0) {
reset();
#endif
void mqttCallback(const MQTT::Publish& pub) {
Serial.print(pub.topic());
Serial.print(" => ");
if (pub.has_stream()) {
int BUFFER_SIZE = 100;
uint8_t buf[BUFFER_SIZE];
int read;
while (read = pub.payload_stream()->read(buf, BUFFER_SIZE)) {
Serial.write(buf, read);
pub.payload_stream()->stop();
Serial.println("had buffer");
Serial.println(pub.payload_string());
String topic = pub.topic();
String payload = pub.payload_string();
if (topic == settings.mqttTopic) {
Serial.println("exact match");
return;
if (topic.startsWith(settings.mqttTopic)) {
Serial.println("for this device");
topic = topic.substring(strlen(settings.mqttTopic) + 1);
String channelString = getValue(topic, '/', 0);
if(!channelString.startsWith("channel-")) {
Serial.println("no channel");
return;
channelString.replace("channel-", "");
int channel = channelString.toInt();
Serial.println(channel);
if (payload == "on") {
turnOn(channel);
if (payload == "off") {
turnOff(channel);
if (payload == "toggle") {
toggle(channel);
if(payload == "") {
#endif
//set led pin as output
pinMode(SONOFF_LED, OUTPUT);
// start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
const char *hostname = HOSTNAME;
WiFiManager wifiManager;
//set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
wifiManager.setAPCallback(configModeCallback);
//timeout - this will quit WiFiManager if it's not configured in 3 minutes, causing a restart
wifiManager.setConfigPortalTimeout(180);
//custom params
EEPROM.begin(512);
EEPROM.get(0, settings);
EEPROM.end();
if (settings.salt != EEPROM_SALT) {
Serial.println("Invalid settings in EEPROM, trying with defaults");
WiFiManagerParameter custom_boot_state("boot-state", "on/off on boot", settings.bootState, 33);
wifiManager.addParameter(&custom_boot_state);
Serial.println(settings.bootState);
Serial.println(settings.blynkToken);
Serial.println(settings.blynkServer);
Serial.println(settings.blynkPort);
WiFiManagerParameter custom_blynk_text("<br/>Blynk config. <br/> No token to disable.<br/>");
wifiManager.addParameter(&custom_blynk_text);
WiFiManagerParameter custom_blynk_token("blynk-token", "blynk token", settings.blynkToken, 33);
wifiManager.addParameter(&custom_blynk_token);
WiFiManagerParameter custom_blynk_server("blynk-server", "blynk server", settings.blynkServer, 33);
wifiManager.addParameter(&custom_blynk_server);
WiFiManagerParameter custom_blynk_port("blynk-port", "port", settings.blynkPort, 6);
wifiManager.addParameter(&custom_blynk_port);
#endif
Serial.println(settings.mqttHostname);
Serial.println(settings.mqttPort);
Serial.println(settings.mqttClientID);
Serial.println(settings.mqttTopic);
WiFiManagerParameter custom_mqtt_text("<br/>MQTT config. <br/> No url to disable.<br/>");
wifiManager.addParameter(&custom_mqtt_text);
WiFiManagerParameter custom_mqtt_hostname("mqtt-hostname", "Hostname", settings.mqttHostname, 33);
wifiManager.addParameter(&custom_mqtt_hostname);
WiFiManagerParameter custom_mqtt_port("mqtt-port", "port", settings.mqttPort, 6);
wifiManager.addParameter(&custom_mqtt_port);
WiFiManagerParameter custom_mqtt_client_id("mqtt-client-id", "Client ID", settings.mqttClientID, 24);
wifiManager.addParameter(&custom_mqtt_client_id);
WiFiManagerParameter custom_mqtt_topic("mqtt-topic", "Topic", settings.mqttTopic, 33);
wifiManager.addParameter(&custom_mqtt_topic);
#endif
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
if (!wifiManager.autoConnect(hostname)) {
Serial.println("failed to connect and hit timeout");
//reset and try again, or maybe put it to deep sleep
ESP.reset();
//Serial.println(custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
Serial.println("Saving config");
strcpy(settings.bootState, custom_boot_state.getValue());
strcpy(settings.blynkToken, custom_blynk_token.getValue());
strcpy(settings.blynkServer, custom_blynk_server.getValue());
strcpy(settings.blynkPort, custom_blynk_port.getValue());
#endif
strcpy(settings.mqttHostname, custom_mqtt_hostname.getValue());
strcpy(settings.mqttPort, custom_mqtt_port.getValue());
strcpy(settings.mqttClientID, custom_mqtt_client_id.getValue());
strcpy(settings.mqttTopic, custom_mqtt_topic.getValue());
#endif
EEPROM.begin(512);
EEPROM.end();
//config blynk
if (strlen(settings.blynkToken) == 0) {
BLYNK_ENABLED = false;
if (BLYNK_ENABLED) {
Blynk.config(settings.blynkToken, settings.blynkServer, atoi(settings.blynkPort));
#endif
//config mqtt
if (strlen(settings.mqttHostname) == 0) {
MQTT_ENABLED = false;
if (MQTT_ENABLED) {
mqttClient.set_server(settings.mqttHostname, atoi(settings.mqttPort));
#endif
//OTA
ArduinoOTA.onStart([]() {
Serial.println("Start OTA");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.setHostname(hostname);
ArduinoOTA.begin();
Serial.println("connected...yeey :)");
ticker.detach();
//setup button
pinMode(SONOFF_BUTTON, INPUT);
attachInterrupt(SONOFF_BUTTON, toggleState, CHANGE);
//setup relay
//TODO multiple relays
pinMode(SONOFF_RELAY_PINS[0], OUTPUT);
//TODO this should move to last state maybe
//TODO multi channel support
if (strcmp(settings.bootState, "on") == 0) {
turnOn();
turnOff();
//setup led
if (!SONOFF_LED_RELAY_STATE) {
digitalWrite(SONOFF_LED, LOW);
Serial.println("done setup");
//ota loop
ArduinoOTA.handle();
//blynk connect and run loop
#endif
//mqtt loop
if (MQTT_ENABLED) {
if (!mqttClient.connected()) {
if(lastMQTTConnectionAttempt == 0 || millis() > lastMQTTConnectionAttempt + 3 * 60 * 1000) {
lastMQTTConnectionAttempt = millis();
Serial.println(millis());
Serial.println("Trying to connect to mqtt");
if (mqttClient.connect(settings.mqttClientID)) {
mqttClient.set_callback(mqttCallback);
char topic[50];
//sprintf(topic, "%s/+/+", settings.mqttTopic);
//mqttClient.subscribe(topic);
sprintf(topic, "%s/+", settings.mqttTopic);
updateMQTT(0);
Serial.println("failed");
mqttClient.loop();
#endif
//delay(200);
//Serial.println(digitalRead(SONOFF_BUTTON));
switch (cmd) {
case CMD_WAIT:
break;
case CMD_BUTTON_CHANGE:
int currentState = digitalRead(SONOFF_BUTTON);
if (currentState != buttonState) {
if (buttonState == LOW && currentState == HIGH) {
long duration = millis() - startPress;
if (duration < 1000) {
Serial.println("short press - toggle relay");
toggle();
} else if (duration < 5000) {
Serial.println("medium press - reset");
restart();
} else if (duration < 60000) {
Serial.println("long press - reset settings");
reset();
} else if (buttonState == HIGH && currentState == LOW) {
startPress = millis();
buttonState = currentState;
break;
