i am using a ttgo t call 800 to control a light from blynk app by a switch/button. when ever power reset is done gprs conection gets established but the digital output of pin gives 0/low irrespective of the switch/buttton state in blynk. after i change the state of button in app then it is getting synced.
for example if the button state is ON/high before power reset after the power comes the digital out put of pin still 0/low . if i change the state from ON to OFF Then ON from app then the digital out put of pin goes 1/high.
so how to get it synced automatically after power reset.
here is the code
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
// Other define
#define TINY_GSM_MODEM_SIM800
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define Serial Serial
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// Include
#include <TinyGsmClient.h>
#include <Wire.h>
#include "utilities.h"
// Vars
const char apn[] = "portalnmms";
const char user[] = "";
const char pass[] = "";
const char auth[] = "sw9gJoulOcFtkjKY5JsANxUF2WmOXKP_";
TinyGsm modem(SerialAT);
// For testing purpose, remove if not needed
BLYNK_WRITE(V5) {
modem.gprsDisconnect();
void checkGPRS()
Serial.println("GPRS check running");
if (!modem.isGprsConnected()) {
if (!modem.gprsConnect(apn, user, pass)) {
delay(10000);
return;
// Set console baud rate
// Keep power when running from battery
Wire.begin(I2C_SDA, I2C_SCL);
bool isOk = setPowerBoostKeepOn(1);
Serial.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
// Set-up modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(3000);
// For GPRS reconnect
timer.setInterval(10000L, checkGPRS);
