Wemos d1 mini clone
Android
• legacy app and local server
• Blynk Library version= 1.1.0
Hi m tying to merge to independent Arduino projects that work independently on their own. The first one is a simple line following car.
const int rightMotor = 14; // D5
const int leftMotor = 5; //D
const int rightSensor = 12; //D7
const int leftSensor = 13; // D8
pinMode(rightMotor, OUTPUT);
pinMode(leftMotor, OUTPUT);
pinMode(rightSensor , INPUT);
pinMode(leftSensor, INPUT);
digitalWrite(rightMotor, !(digitalRead(rightSensor)));
digitalWrite(!(leftMotor), !(digitalRead(leftSensor)));
The second one is a joystick-controlled car using blynk.
#define BLYNK_AUTH_TOKEN ""
#define ipconfig ""
#define port 8080
#define leftMotor 5 // D3
#define rightMotor 14 //D4
int x=0;
int y=0;
char auth[] = BLYNK_AUTH_TOKEN; //Enter your Blynk auth token
char ssid[] = "";
char pass[] = "";
digitalWrite(leftMotor, HIGH);
digitalWrite(rightMotor, HIGH);
Blynk.begin(auth, ssid, pass, ipconfig, 8080);
timer.setInterval(500L, car);
BLYNK_WRITE(V0) {
x = param[0].asInt();
y = param[1].asInt();
//Get the slider values
void car() {
if (x==0 && y==0){
stopda();
}else
if (y > 1) {
forward();
Serial.println("carForward");
} else
if (y < -1) {
stopda();
Serial.println("stop!");
} else
if (x < -1) {
left();
Serial.println("carLeft");
} else
if (x > 1) {
right();
Serial.println("carRight");
} else
if(y<=1 && y >=-1 && x>=-1 && x <=1) {
stopda();
Serial.println("carstop");
} else{}
Blynk.run();// Run the blynk function
void forward(){
digitalWrite(leftMotor,LOW);
digitalWrite(rightMotor,LOW);
void left(){
digitalWrite(leftMotor,HIGH);
void right(){
digitalWrite(rightMotor,HIGH);
void stopda(){
Both work perfectly independently.
My problem arises when i try to merge them into 1 function
Ive added a button to whose state is read and if pressed the linefollow() is executed and if its not pressed car() for joystick mode is executed
Now the joystick mode in this implemented version works fine but when the mode is switched to linefollow. it doesnt do anything
#define ipconfig ""
#define port 8080
int x=0;
int y=0;
int button1;
char ssid[] = ""; //Enter your WIFI name
char pass[] = ""; //Enter your WIFI passowrd
timer.setInterval(500L, check);
BLYNK_WRITE(V0) {
BLYNK_WRITE(V2) {
button1 = param.asInt();
BLYNK_WRITE(V1) {
button2 = param.asInt();
void car() {
if (x==0 && y==0){
stopda();
}else
if (y > 1) {
forward();
} else
if (y < -1) {
stopda();
} else
if (x < -1) {
left();
} else
if (x > 1) {
right();
} else
stopda();
} else{}
void forward(){
void left(){
void right(){
void stopda(){
void linefollow()
Serial.print(digitalRead(rightSensor));
Serial.print( " ");
Serial.println(digitalRead(leftSensor));
void check(){
if(button1==0){
car();
else if (button1==1){
linefollow();
