Problem in connection
Hi dear .
I face problem while connection app with arduino uno i do every steps but still their is problem in connection it is connect after 2 mintiest disconnect .
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = “”;
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = “”;
char user[] = “”;
char pass[] = “”;
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(10, 11); // RX, TX
TinyGsm modem(SerialAT);
// Set GSM module baud rate
SerialAT.begin(115200);
delay(3000);
Serial.println(“Initializing modem…”);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock(“1234”);
So you’re using some sort of GPRS shield with your Uno?
More details of how this is wired and powered would be useful.
Your Blynk library is extremely out of date, so you should update then and your other libraries.
Sharing your code (correctly formatted with triple backticks) would also be a good idea.
