I’m trying use the function BLYNK_CONNECT to synchroniza my virtual pins in system initialization, but this error appers for me.
error: redefinition of 'void BlynkOnConnected()'
error: 'void BlynkOnConnected()' previously defined here
note: in expansion of macro 'BLYNK_CONNECTED'
my code is:
BLYNK_CONNECTED(){
Blynk.syncAll();
I’m using Arduino MRK1000.
Somebody have a suggestion to solve this problem?
It’s really difficult to provide any advice or insight based on the small amount of info that you’ve provided.
When you create a new “Need help…” or “Issues & Errors” topic then you’re asked to provide this sort of information:
Add details :
• Blynk Library version
• Add your sketch code.
As this is a compiler error then just showing a couple of lines of code isn’t really enough. The error could be caused by a missing or mis-placed curly bracket in another part of your code or using (as the error message implies) the BLYNK_CONNECTED()
command more than once in your code.
Can you add more details, and your full code please?
