Hey!
I am trying to connect to the local server installed on a windows 7 machine with an ipad. The server starts correctly by running:
java -jar server-0.19.2.jar -dataFolder C:\Users\Bladetips\blynk_server -serverConfig C:\Users\Bladetips\blynk_server\server.properties
When trying to connect the app to the server I get “Sorry, server can’t talk now. Try later.”
The log file gives:
2016-11-17 22:52:26.170 INFO - Using data dir ‘C:\Users\Bladetips\blynk_server’
2016-11-17 22:52:26.230 INFO - Region : local
2016-11-17 22:52:26.814 INFO - Initializing gmail smtp mail transport. Username : rogelioskiutc2010@gmail.com. SMTP host : smtp.gmail.com:587
2016-11-17 22:52:27.568 WARN - Found server certificates but no client certificate for ‘C:\Users\Bladetips\blynk_server’ path. Using one way ssl.
2016-11-17 22:52:27.970 INFO - Hardware plain tcp/ip server listening at 8442 port.
2016-11-17 22:52:27.970 INFO - Hardware SSL server listening at 8441 port.
2016-11-17 22:52:27.970 INFO - Application server listening at 8443 port.
2016-11-17 22:52:27.970 INFO - HTTP API server listening at 8080 port.
2016-11-17 22:52:27.970 INFO - HTTPS API server listening at 9443 port.
2016-11-17 22:52:27.970 INFO - HTTPS Admin UI server listening at 7443 port.
2016-11-17 22:52:27.970 INFO - Web Sockets server listening at 8082 port.
2016-11-17 22:52:27.970 INFO - Web SSL Sockets server listening at 8081 port.
2016-11-17 22:52:27.970 INFO - Mqtt hardware server listening at 8440 port.
2016-11-17 22:53:41.875 WARN - No order field ‘id’
When accesing the administration UI, I cannot access mail.properties and receive “State change error : undefined”. The last line in the log file (warning - no order field ‘id’) is generated when I try to access mail.properties here.
Do you know where the problem could be coming from?
Many thanks
