Hi again, now I have another problem with NodeMCU. This time, In one state of my program, I send my Node to deepSleep 5 seconds, then it wakes up, test if the time previously setted and the RTC matches, if not matches, it goes again to sleep. The problem is, that I want to make that if the Blynk App is opened, the Node stops the sleep loop until the app is closed. I tried used BLYNK_APP_CONNECTED and BLYNK_APP_DISCONNECTED, but It didn’t work, because it has to be a perfect timing to trigger that event when the Node is awake (when it checks time). So, I wonder, is there a function that checks if the App IS connected, and not only when you open it? I’m using a private server. I hope that I give enough information.
Please post your (formatted) code in case someone needs to go over it and test it themselves.
A couple of ideas…
Did you enable the NOTIFY DEVICES WHEN APP CONNECTED feature in the Project Settings?
Have you checked if the
BLYNK_APP_CONNECTED()
can be tested as a boolean? (I haven’t yet)
EDIT - I have tried, but it fails to compile
if (BLYNK_APP_CONNECTED() == 1) {
//App is active
// App is NOT active
- Perhaps you could also try experimenting with the
BLYNK_READ()
function and perhaps a simple display widget set to a 1 second reading rate (the shortest time available)… Unless the developers have changed it, that timed widget should only call and process the function when the the Project is active (EDIT - confirmed this still works that way).
Not quite sure off the top of my head what you could use in that function to act as a “App is alive” flag…? But then theBLYNK_APP_DISCONNECTED()
could be used to resume sleep.
- Yes, I did, I forgot to mention it.
- No, It doesn’t work, it only can be used as a function.
- It appears to be working, but sometimes it takes a couple of seconds to the wake up and the reading of the display to match.
I leave part of my code that make it works.
//controlSleep it's initialy true
V11 is a value display that shows '0' when the Node is awake, and '1' when is still sleeping (it only sees when you open the app until the program enters to BLYNK_READ).
Blynk.virtualWrite(V11, 1);
controlSleep = true;
BLYNK_READ(V11)
Blynk.virtualWrite(V11, 0);
controlSleep = false;
//Sleep is called in a function who is always repeating in the void loop()
void Sleep(void)
if (controlSleep)
ESP.deepSleep(2e6);
//Sleep for 2 seconds instead of 5 (to recognize quickly the aperture of the app)
if (WiFi.status() != WL_CONNECTED)
Serial.println("Conectando");
WiFi.begin(ssid, pass);
It needs a condition if you forgot the app open, but it will be a work for tomorrow.
You could implement a long timeout timer… so if the App is still open 30 minutes (or whatever) later, then sleep anyhow.
Yeah, i though the same, is a little more of work, but well, I wanna polish my program the best as I can. Surely I will post the updated code when I make it.
