I’m trying to build a project for a Particle Argon board using the library I downloaded here:
I’m using 5.1.0 of the Particle OS.
I’m getting the following error when I build:
Creating c:/Users/jayk/work/particle/monitor2/monitor2/target/5.1.0/argon/platform_user_ram.ld …
c:/users/jayk/.particle/toolchains/gcc-arm/10.2.1/bin/…/lib/gcc/arm-none-eabi/10.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: …/…/…/build/target/user/platform-12-m/monitor2/\libuser.a(monitor2.o): in function BlynkProtocol<BlynkTransportParticle>::processInput()': c:/Users/jayk/work/particle/monitor2/monitor2/lib/blynk/src/Blynk/BlynkProtocol.h:389: undefined reference to BlynkWidgetWriteInternalPinDBG’
c:/users/jayk/.particle/toolchains/gcc-arm/10.2.1/bin/…/lib/gcc/arm-none-eabi/10.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: c:/Users/jayk/work/particle/monitor2/monitor2/lib/blynk/src/Blynk/BlynkProtocol.h:388: undefined reference to `BlynkWidgetWriteInternalPinVFS’
I’m including blynk.h in my code and I have a #define BLYNK_PRINT Serial before that.
My code used to work with an older version of the Blynk lib.
