I have installed a local Blynk Server on a Raspberry Pi 3.
The server is correctly configured and I can run without problem my project.
The problem is that everytime I reboot my Raspberry the Local Server I need to restart it using the terminal command âjava -jar server-0.29.0-java8.jar -dataFolder /home/pi/Blynkâ
I have also tried to both insert in crontab -e the following line "@reboot java -jar /home/pi/server-0.29.0.java8.jar -dataFolder /home/pi/Blynk & " and also in the sudo crontab -e the same line.
I have also open,using terminal,the file /etc/rc.local and I have insert the following line âjava -jar /home/pi/server-0.29.0.jar -dataFolder /home/pi/Blynk &â before the line exit0.
The problem with that is⌠everyones setup is different, and thus one âcorrectâ command will not necessarily be working for anotherâs setup.
That is one reason that Local Server should be considered an expert use only⌠you need to know more than just basic Blynk commands to get it running smoothly.
