I have a private blynk server running on a linux Ubuntu 16.04.6 LTS box. Everything works fine except when the code tries to send out a push notification. It keeps giving the following error in the logs:
ERROR- Error sending push. Reason General OpenSslEngine problem
Any idea what might be the cause of that?
ubuntu@instance-20200208-1543:~/logs$ tail -f blynk.log
09:55:30.564 WARN - ATTENTION. Server certificate paths (cert : '/home/ubuntu', key : '/home/ubuntu') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
09:55:33.017 INFO - HTTP API and WebSockets server listening at 8080 port.
09:55:33.020 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
09:55:33.020 INFO - Mqtt hardware server listening at 8440 port.
09:55:33.041 INFO - Starting up certificate retrieval process for host xx.xx.net and email xx@gmail.com.
09:55:35.239 INFO - admin@blynk.cc hardware joined.
09:57:31.480 INFO - admin@blynk.cc hardware joined.
09:58:22.133 INFO - admin@blynk.cc hardware joined.
09:58:23.773 INFO - xx@gmail.com hardware joined.
09:59:30.861 INFO - admin@blynk.cc hardware joined.
10:05:59.653 ERROR- Error sending push. Reason General OpenSslEngine problem
10:05:59.656 ERROR- Error sending push. Reason General OpenSslEngine problem
