I got a real head bonker… what am I missing this code compiled earlier and is running fine. Now there are endless errors.
/*For sonoff use generic 8266
* set flash to 1m (0 SPIFFS)
* DOUT
* 9e82e1 label
* gp12 relay
* gp5 relay
* gp13 blue led
* gp10 on board button
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <WidgetRTC.h>
#include <TimeLib.h>
char auth[] = "*****";
char ssid[] = "***********";
char pass[] = "**********";
WidgetLCD lcd (V0);
const int interruptPin = 10; //GPIO pin 10
int ReCnctCount;
int ReCnctFlag;
long resetTime;
int SThour;
int STmin;
int litersReset = 0;
bool d1Trig = false; //Bool to store interupt for D1
bool d2Trig = false; //Bool to store interupt for D2
int counterLiters;
WidgetLED trig1LED (V5);
WidgetLED trig2LED (V6);
WidgetRTC rtc;
void setup(){
WiFi.begin(ssid,pass);
Blynk.config(auth);
Blynk.connect();
ArduinoOTA.setHostname("waterMeter1");
ArduinoOTA.begin();
These timer.setIntervals are throwing errors says “checkcounterReset not declared in this scope”
timer.setInterval(1000L,checkcounterReset);
delay(50);
timer.setInterval(1000L,WiFistrength);
delay(75);
timer.setInterval(1000L,printTIME);
lcd.print(0,0, "Sonoff started");
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin),counterAdd,RISING);
pinMode(0, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(0), d1Trigopp, FALLING);
attachInterrupt(digitalPinToInterrupt(9), d2Trigopp, FALLING);
Blynk.virtualWrite(V4,counterLiters);
delay(500);
lcd.clear();
Blynk.syncAll();
setSyncInterval(720*60);
BLYNK_CONNECTED(){
Serial.println("Connected");
ReCnctCount = 0;
rtc.begin();
void loop(){
ArduinoOTA.handle();
if (Blynk.connected()){ //If Blynk connected run as normal
else if (ReCnctFlag == 0){ //test connection flag
ReCnctFlag = 1; //set connection flag
timer.setTimeout(30000L,[](){ //Lambda "Reconnection" timer function
ReCnctFlag = 0;
ReCnctCount++; //count up reconnection attempts
Blynk.connect(); //try to connect again
/* water meter add */
void d1Trigopp()
d1Trig = true; //On interupt set D1 bool to true
lcd.print(0,1, counterLiters);
trig1LED.on();
trig2LED.off();
Blynk.virtualWrite(V2, 2);
void d2Trigopp()
d2Trig = true; //On interupt set set D2 bool to true
if(d1Trig == true && d2Trig == true) //Check both variables
counterLiters ++; //increment counter
Blynk.virtualWrite(V4,counterLiters); //print counter
d1Trig = false; //immediately set values to false so exits loop
d2Trig = false;
trig1LED.off(); //virtualLEDs to show which one triggered last
trig2LED.on();
void WiFistrength() //prints wifi strength
long rssi = WiFi.RSSI();
//lcd.clear();
lcd.print(4,0, rssi);
Blynk.virtualWrite(V21,rssi);
void checkcounterReset() //time input
if(hour()== SThour){ //daily output total liters to super chart 1 minute before clearing
if(minute()== (STmin +1)){
Blynk.virtualWrite(V15,counterLiters);
if(hour() == SThour){ //daily clear total liters
if(minute() == STmin){
if(litersReset == 0){
counterLiters = 0;
litersReset = 1; //change flag so only exicute once
lcd.print(3,1,litersReset);
lcd.print(4,1," ");
if(hour()== SThour){ //change flag so that counter can be reset next day
litersReset = 0;
lcd.print(3,1, litersReset);
These BLYNK_WRITE functions don’t compile “a function-definition is not allowed here before ‘{’ token”
BLYNK_WRITE(V1)
counterLiters = 0; //manual reset
BLYNK_WRITE(V16)
if (param.asInt()){ //manual reset esp if needed
lcd.print(8,0, "ESPReset");
timer.setTimeout(5000L,resetESP);
void resetESP()
ESP.reset();
BLYNK_WRITE(V10)
TimeInputParam t(param); //time input
SThour = t.getStartHour();
STmin = t.getStartMinute();
lcd.print(3,1,(String("Strt ") +
t.getStartHour() + ":" +
t.getStartMinute() + ":" +
t.getStartSecond()));
BLYNK_WRITE(V13)
if(param.asInt()){ //manual uptick for testing
counterLiters ++;
And these void functions cause errors!!
void printTIME() //what it says!
String currentTime = String(hour())+ ":" +minute()+ ":" +second();
Blynk.virtualWrite(V14, currentTime);
Its got to be something simple but I can’t find it.
Everytime I comment 1 thing out there is another error.
Does this compile for anyone else?
