Prevent gpio from toggling at power up
@mat_pav Actually, I don’t remember what I had for lunch today so, remembering what I did in January, is quite a challenge for my memory :wink:
Even though this’ not Blynk related, if I was to redo it now I’d do this way [not tested and not sure if is the best way to go]
Create a py file (initRelays.py) with the following code:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
#set array for relay pins
relayPins = [17,18,22,23]
#set output mode for all relay pins
GPIO.setup(relayPins, GPIO.OUT)
#set relays GPIO to HIGH (off)
for x in relayPins:
	GPIO.output(x, GPIO.HIGH)
Then edit your crontan (crontab –e) and add on the last line
@reboot python /path/to your file/initRelays.py
reboot
If you’re having a problem with your Blynk code, post it and someone will definitely help you.
Good luck.
