Power Control using Blynk
Hello all,
Here is a short project to show the flexibility of Blynk. Here I control the fun using the ESP8266, and some Blynk code.
I use the Omron TRIAC part #: Omron G3NA-220B-DC5-24 , I like this TRIAC because is Arduino Friendly, the ESP8266 is powered by 3.2 volts, still able to trigger ON the TRIAC gate. that is it. Just having fun :slight_smile:
From here, you can take it to the next level. How about a Temperature/Humidity sensor? If the temp is 85 degrees, turn on the A/C, if the R% humidity is 90, outch! That is humid! Turn on the dehumidifier, etc,etc.
Here is a youtube video:
https://www.youtube.com/watch?v=oA6lpMWUJ90
          Power Control -  Having fun with Blynk
          Author: Alex Rodriguez
          Reviewed: April., 3, 2016
char auth[] = "xxxxxxxxxxxxxxxxxxxx";
// Hardware variables
#define TRIAC 4
  pinMode(TRIAC, OUTPUT);
  Blynk.begin(auth, "SSID", "PASSWORD");
BLYNK_WRITE(V7)
  if (param.asInt() == 0)
  digitalWrite(TRIAC, LOW);
  digitalWrite(TRIAC, HIGH);
// ==============( Void Loop  ) ==================================
