Hello, I am new to this community so I donât know if my problem has already been solved, but âProblems with particle photon and Blynkâ under âProjects made with Blynkâ seems to be having the same problem, and no one really addressed it
I am making a device using Particle Photon and viewing/saving the data using Blynk. The device keeps counting âcyclesâ and if it hasnât been used for quite sometime (20 sec) then it goes to sleep, and wakes up on an interrupt pin. Periodically, I log on to the interned and purge the data to Blynk. I am using SYSTEM_MODE(SEMI_AUTOMATIC); to control when I connect to the internet, and SYSTEM_THREAD(ENABLED); because itâs crucial for me to run processes in parallel and not lose data while trying to connect to WiFi/send data to BlynkâŚetc.
Unfortunately, when Blynk.begin(auth); is called without internet connection, the device stays offline (white LED breathing) and doesnât proceed with setup()/void loop() {}; (I think this is whatâs happening with the person I mentioned from the other post). In order to solve that problem I moved Blynk.Begin(); to a much later point in the code when an internet connection has been established.
However, when Blynk.begin(auth) is called it doesnât allow threading to occur, void loop(){} isnât running and the function doesnât return until several seconds has passed thatâs the time when I am currently loosing data and at this point the Photon is just trying to log on to the internet/establish a connection without using another thread to run void loop(){};
Any solutions for this? Is it possible to SYSTEM_THREAD(ENABLED) with Blynk? Any help would be highly appreciated, Thanks!
Here is my code:
#include <blynk.h>
#include "Particle.h"
#include "application.h"
#define Halleffect D1
char auth[] = "";
int WheelCount = 0;
int previous_state=1;
int current_state= 1;
unsigned int T1= 0;
unsigned int T2= 0;
unsigned int T_lapse_sleep= 0;
unsigned int T_lapse_data= 0;
int control = 1;
int t =0;
int h;int m=0;
int previous_h= 0;
int previous_m=0;
bool c = FALSE;
// SYSTEM_THREAD(ENABLED);
// SYSTEM_MODE(SEMI_AUTOMATIC);
delay (4000);Serial.println("starting at the beggining of setup");
t = Time.now();
timer.setInterval(1000L, WriteWheelData);
pinMode(Halleffect,INPUT_PULLUP);
pinMode(D7, OUTPUT);
T1= millis();
current_state = digitalRead(Halleffect);
//Serial.println(current_state);
if (current_state == 0){ //if a cycle is read
if (previous_state != current_state){
WheelCount += 1;
Serial.print("Wheel count is: ");
Serial.println(WheelCount);
digitalWrite (D7, HIGH);
delay (100);
digitalWrite (D7, LOW);
T2= millis();
previous_state= current_state ;
control = 1;
else{ //a cycle isn't read
previous_state= current_state;
T_lapse_sleep = millis() - T2;
if (T_lapse_sleep > 20000){ // sleep if wheel isn't used within 30 seconds
// previous_h= Time.hour();
// Serial.print("Previous hour is: ");Serial.print(previous_h);
// previous_m= Time.minute();
// Serial.print("Previous minute is: ");Serial.print(previous_m);
Serial.println("Sleep");
System.sleep(Halleffect,FALLING);
delay(100);
//c= check_time();
control = 0;
T1= millis();
T2= millis();
Internet();
void Internet(){
T_lapse_data = millis() - T1;
if (T_lapse_data > 10000 & control == 1 ){
//if (control == 1 & (c || T_lapse_data > 10000) ){ // if it has been turned off for 10 mins or if it has been running for 1 min
if (WiFi.ready() == FALSE) {
WiFi.on();
Serial.println ("WiFi On ");
WiFi.connect();
Serial.println ("WiFi Connecting");
Blynk.begin(auth);
Serial.println ("Connected!");
T1= millis();
void WriteWheelData()
Blynk.virtualWrite(V1, WheelCount);
WheelCount = 0;
bool check_time(){
h= Time.hour();
m= Time.minute();
if (((h == previous_h) || (h > previous_h)) & (m >= previous_m + 1)){return TRUE;}
else{ return FALSE;}
