I installed the lib. And under USAGE section i found this code
#define TIMER_INTERRUPT_DEBUG 1
#include "ESP8266TimerInterrupt.h"
#ifndef LED_BUILTIN
#define LED_BUILTIN 2 // Pin D2 mapped to pin GPIO2/ADC12 of ESP32, control on-board LED
#endif
volatile uint32_t lastMillis = 0;
void IRAM_ATTR TimerHandler(void)
static bool toggle = false;
static bool started = false;
if (!started)
started = true;
pinMode(LED_BUILTIN, OUTPUT);
#if (TIMER_INTERRUPT_DEBUG > 0)
if (lastMillis != 0)
Serial.println("Delta ms = " + String(millis() - lastMillis));
lastMillis = millis();
#endif
//timer interrupt toggles pin LED_BUILTIN
digitalWrite(LED_BUILTIN, toggle);
toggle = !toggle;
#define TIMER_INTERVAL_MS 1000
// Init ESP8266 timer 0
ESP8266Timer ITimer;
Serial.println("\nStarting");
// Interval in microsecs
if (ITimer.attachInterruptInterval(TIMER_INTERVAL_MS * 1000, TimerHandler))
Serial.println("Starting ITimer OK, millis() = " + String(millis()));
Serial.println("Can't set ITimer correctly. Select another freq. or interval");
But the code is not compiling
sketch_nov25c:11:16: error: expected initializer before 'TimerHandler'
exit status 1
Can you please tell me whether the lib has been installed properly ?
Can you please shed more light on this ?? I am finding it difficult to understand the examples you have provided. And even the SwitchDebounce example from your lib is not compiling.
Can you please help me out ?
Sorry to know that you have the problem with installing library.
Can you check that you
Already copy the whole directory ESP8266TimerInterrupt-master into libraries directory, normally ~/Arduino/libraries/ for Linux/Ubuntu
Use the file in the examples subdirectory under ESP8266TimerInterrupt-master to avoid copying mistakes. Just a missing or extra {, } or ; can create issue.
Check if you have the latest Arduino 1.8.10. I havenāt checked the earlier versions.
Check if you have ESP8266 newer library version, such as 2.6.0 or 2.6.1. I havenāt checked the earlier version.
I tested again and again your posted code as well as files in the library without any compiling error, using Arduino 1.8.10 and ESP8266 library v2.6.1.
Iāll find out if the earlier libraries or Arduino versions can create this kind of error.
The lean/mean function to use in ISR (Interrupt Service Routine) means that it must be short, not using uncontrolled while, for, etc. loop that takes lot of processing time, and especially donāt use any delay() or call any function doing so.
Generally, this function is part of ISR, and must follow guidelines to write ISRs.
Thatās the catch in order to bypass being blocked.
Can you try removing IRAM_ATTR at TimerHandler(void)
void /*IRAM_ATTR*/ TimerHandler(void)
Itās better you update the Arduino to 1.8.10 and ESP8266 library to 2.6.1 as theyāre stable and better now.
So with your lib i should be getting the buttons working even if there is connection happening ?
Yes, thatās the power of ISR. Certainly. it also depends on how you write your function. Anyway, Iāll use your application as an example to use either ISR directly or to use Hardware Timer to poll.
This is something I plan to do to add more examples showing the benefit of ISR. I will finish it shortly and let you know then.
This is the first version using ISR directly to detect the SW and control lamp relay. It wonāt stop functioning even if some other function is blocking. I tested and itās working OK on Arduino1.8.10 and esp8266 2.6.1
Here is the version using ISR to detect the SW press and the Hardware Timer to poll and make decision.
Be noted that all the unnecessary calls, such as delay() or
Blynk.virtualWrite(VPIN1, LampState1);
are either deleted or pushed out to Blynk Software Timer.
//#define BLYNK_DEBUG true
//#define USE_BLYNK_WM true
#define USE_BLYNK_WM false
#define USE_SSL false
#if USE_BLYNK_WM
#if USE_SSL
#include <BlynkSimpleEsp8266_SSL_WM.h> //https://github.com/khoih-prog/Blynk_WM
#else
#include <BlynkSimpleEsp8266_WM.h> //https://github.com/khoih-prog/Blynk_WM
#endif
#else
#if USE_SSL
#include <BlynkSimpleEsp8266_SSL.h>
#define BLYNK_HARDWARE_PORT 9443
#else
#define BLYNK_HARDWARE_PORT 8080
#endif
#endif
// Init ESP8266 Hardware timer
#if !USE_BLYNK_WM
#define USE_LOCAL_SERVER true
// If local server
#if USE_LOCAL_SERVER
char blynk_server[] = "yourname.duckdns.org";
#else
char blynk_server[] = "";
#endif
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
#endif
#define DEBOUNCE_TIME 25
#define LONG_BUTTON_PRESS_TIME_MS 10
#define DEBUG_ISR 0
#define VPIN1 V1
volatile unsigned long lastDebounceTime = 0;
volatile bool buttonPressed = false;
bool alreadyTriggered = false;
void lightOn1();
void lightOff1();
boolean LampState1 = 0;
boolean SwitchReset1 = true;
const int RelayPin1 = D1; //D2;
const int buttonPin = D3; //D1;
BlynkTimer Timer;
unsigned int myServerTimeout = 3500L; // 3.5s server connection timeout (SCT)
unsigned int myWiFiTimeout = 3200L; // 3.2s WiFi connection timeout (WCT)
unsigned int buttonInterval = 2000L; // 2.0s update button state
void ICACHE_RAM_ATTR Falling();
void ICACHE_RAM_ATTR Rising();
pinMode(RelayPin1, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(buttonPin), Falling, FALLING);
// Interval in microsecs, so MS to multiply by 1000
// Be sure to place this HW Timer well ahead blocking calls, because it needs to be initialized.
if (ITimer.attachInterruptInterval(TIMER_INTERVAL_MS * 1000, HWCheckButton))
Serial.println("Can't set ITimer. Select another freq. or interval");
Serial.println("Initialize Blynk");
#if USE_BLYNK_WM
Blynk.begin();
#else
unsigned long startWiFi = millis();
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
delay(500);
if(millis() > startWiFi + myWiFiTimeout)
Serial.println("Check the WiFi router. ");
break;
Blynk.config(auth, blynk_server, BLYNK_HARDWARE_PORT);
Serial.println("This is HomeControl-TEST");
Blynk.connect();
#endif
Timer.setInterval(buttonInterval, checkButton);
void Rising()
unsigned long currentTime = millis();
unsigned long TimeDiff;
#if (DEBUG_ISR > 0)
Serial.println("rising");
#endif
TimeDiff = currentTime - lastDebounceTime;
if ( digitalRead(buttonPin) && (TimeDiff > DEBOUNCE_TIME) )
#if (DEBUG_ISR > 0)
Serial.println("Button Released");
#endif
//ButtonCheck1();
if (TimeDiff > LONG_BUTTON_PRESS_TIME_MS)
#if (DEBUG_ISR > 0)
Serial.printf("TimeDiff = %d ms => long Button Press (with release)\n", TimeDiff );
#endif
#if (DEBUG_ISR > 0)
Serial.println("Short Button Press");
#endif
lastDebounceTime = currentTime;
void Falling()
#if (DEBUG_ISR > 0)
Serial.println("falling");
#endif
if ( !digitalRead(buttonPin) && (currentTime > lastDebounceTime + DEBOUNCE_TIME))
#if (DEBUG_ISR > 0)
Serial.println("Button Pressed");
#endif
//ButtonCheck1();
buttonPressed = true;
attachInterrupt(digitalPinToInterrupt(buttonPin), Rising, RISING);
Timer.run();
void HWCheckButton()
if (!alreadyTriggered && buttonPressed)
alreadyTriggered = true;
#if (DEBUG_ISR > 0)
Serial.println("Long Button Press");
#endif
// Doing something here without waiting for button released (long press)
ButtonCheck1();
else if (!buttonPressed)
// Reset flag when button released to avoid triggered repeatedly
ButtonCheck1();
void checkButton()
void ButtonCheck1()
boolean SwitchState1 = (digitalRead(buttonPin));
if (!SwitchState1 && SwitchReset1)
if (LampState1)
lightOff1();
lightOn1();
SwitchReset1 = false;
else if (SwitchState1)
void ToggleRelay1()
LampState1 = !LampState1;
if (LampState1)
lightOn1();
lightOff1();
void lightOn1()
digitalWrite(RelayPin1, LOW);
LampState1 = 1;
void lightOff1()
digitalWrite(RelayPin1, HIGH);
LampState1 = 0;
BLYNK_WRITE(VPIN1)
int SwitchStatus1 = param.asInt();
if (SwitchStatus1 == 2)
ToggleRelay1();
else if (SwitchStatus1)
lightOn1();
lightOff1();
@khoih
I tried to upgrade to arduino version to 1.8.10 and updated esp8266 core to 2.6.1
Now none of my previous codes are compilingā¦
It says multiple libraries were found⦠I tried deleting all the user files from previous build and reinstalled !! But no use. Should i change back to the older version ?? Sure its not a blynk related issue. But want to know whether you faced the same issue earlier when you upgradedā¦
EDIT
But the code compiles with ESP core 2.5.2
Gives no errorā¦
Sorry to know that you got problem arising from updating.
Normally, multiple libraries were found warning is OK, provided the compiler uses the correct intended library. So you have to know what the real error is.
If you can use 2.5.2 without problem, then use it for now. But which Arduino version? 1.8.10 or 1.8.7?
I havenāt experienced that kind of problem and donāt have direct knowledge of what the issue is. Which OS are you running (Win/Ubuntu/Linux)??
Anyway, itās better to go to Arduino forum to search or ask for advice. You can also go to my GitHub
and post Issues there, and Iāll try my best to help you out. Iām afraid here is not a good place to deal with that problem.
RE: random reset of the board: ets Jan 8 2013,rst cause:2, boot mode:(3,6)
The reset came from your reset pin. This means you might use the wrong pins, or some other external devices pulse the RST pin. Did you change the pins in the code?
Iāve been running several boards continuously from the time I posted the code until now without any issue.
need to check whether this core will solve the problem or not.
i am on win8.1
same here @PeteKnight i guess Pete has not come across this thread or may be busy
I guess the problem is, i am using wifimanager to input the credentials !! May that is taking up a lot of memory !
Any ways i will check it out with core 2.5.2 and let you know !!
The new release v1.0.1 of ESP8266TimerInterrupt with new Blynk examples (inspired from your code) has been published.
It fixes all the pre-1.8.10-Arduino and pre-2.6.0-ESP8266-core compiler error issues as well as start-up and random resets youāve experienced.
Please go to GitHub to download and test in examples subdirectory. They are too long to post here.
You can test using 1.8.10 and 2.5.2. I tested with 1.8.9 amd 2.5.2 OK.
@khoih
Hello !!
Sorry for the late update.
I tried your new example ! But it still crashes while trying to connect to the server. But works fine when both wifi and internet is up. If only wifi is available without the internet it crashes when i push the button⦠I tried changing the pins, changed the nodemcu module !! But still the same.
Is there any other way out ?
Hello @khoih
Problem with the crash was
i had Blynk.virtualWrite on the Hardware Timer. So as soon as the connection drops(internet) it was crashingā¦
My bad i did not pay attention to this⦠Sorry !!
