Hej,
so i would like to pass param to a function.
my goal is to have multiple blynk_writes(Vx) and only 1 function. I am using Time Input Widget. I am not sure what kind of type is param.
Something like this:
BLYNK_WRITE(V1) {
blynkTimeInput(param);
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
void blynkTimeInput(type??? param) {
TimeInputParam t(param);
//do something
Pavel
August 16, 2017, 7:32pm
2
Your code is incorrect
Example from http://examples.blynk.cc shows:
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
then you collect all `pinValues’ you need and pass them to function. Of course they all should be global variables
void blynkTimeInput(pinValue1, pinValue2, pinValue3)
//do something
my code works if i use like this:
BLYNK_WRITE(V1) {
//do something
long startTimeInSecs = param[0].asLong();
long endTimeInSecs = param[1].asLong();
but now i wont to move it to function like in my first post …
so i want to pass whole “param” not a single pinValues…
[AdvancedTimeInput](https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=Widgets%2FTimeInput%2FAdvancedTimeInput)
ok i have found a solution for my problem:
BLYNK_WRITE(V1) {
void blynkTimeInput(const BlynkParam& param) {
//do something
> BLYNK_WRITE(V1) {
> //do something
AdvancedTimeInput
> BLYNK_WRITE(V1) {
> //do something
Try putting your code like this, you can do this by using , its easier on the eyes
Gunner
August 16, 2017, 9:39pm
5
I fixed his posts with the recommended three backticks fore and aft.
It seems the OP resolved whatever he was looking to accomplish, so marking this solved.
I was waiting for that picture to pop up
