Particle Photon DAC
Am I correct in assuming that that there is no way to choose the DAC as an analogue output pin for example a slider widget.
If not I will just have to use a virtual pin to read the slider and then write it to the DAC in code :frowning:
  1. @vshymanskyy please comment
  2. Using Virtual Pins is just 3 lines of code…
Yes, that’s what I am doing now - but I am always looking for ways to improve the efficiency of my code :wink:
