[SOLVED] Particle Electron cycling connection with Blynk
Does anyone know what the optimum settings are for the Particle Electron to run Blynk. I have one running the latest particle firmware 6.2.0 with basic blynk sketch created as seen on the Blynk sketch builder.
It constantly cycles through connecting - resetting - connecting, sometimes all it does is register onto the 3g network and thats it.
When I run a basic particle led blinking sketch without any blynk code it runs fine.
Anyone experiencing the same thing and can anyone offer some advice.
Probably becasue a basic blink sketch doesn’t need to connect to a server :wink:
Post your entire sketch here so we can see if you have the “optimum” settings (block out part of your auth code when posting).
Here’s the code. It’s straight from the the Blynk code builder…
        Follow us:                  http://www.fb.com/blynkapp
                                    http://twitter.com/blynk_app
      You’ll need:
       - Blynk App (download from AppStore or Google Play)
       - Particle Electron board
      started. Think of them as LEGO bricks  and combine them as you wish.
      example.
    // Uncomment this, if you want to set network credentials
    //#include "cellular_hal.h"
    //STARTUP(cellular_credentials_set("broadband", "", "", NULL));
    // Run "ping blynk-cloud.com", and set Blynk IP to the shown address
    #define BLYNK_IP        IPAddress(45,55,130,102)
    // Set Blynk hertbeat interval.
    // Each heartbeat uses ~90 bytes of data.
    #define BLYNK_HEARTBEAT 60
    // Set Particle keep-alive ping interval.
    // Each ping uses 121 bytes of data.
    #define PARTICLE_KEEPALIVE 20
    #include <blynk.h>
    char auth[] = "****";
      delay(2000);
      Particle.keepAlive(PARTICLE_KEEPALIVE);
      Blynk.begin(auth, BLYNK_IP);
      // to avoid delay() function!
Have you confirmed this address via PING from a PC?
Oh, and have you tryed varients like
#define BLYNK_IP        (45,55,130,102)
or
#define BLYNK_IP        "45,55,130,102"
or even
#define BLYNK_IP        "45.55.130.102" // using periods instead of commas
Can you show your serial monitor readout when trying to connect?
Apologies @Gunner the Blynk IP i am using is 45,55,96,146. The code won’t compile with the variations you’ve suggested. Also I can open the serial monitor via the command prompt…"particle serial monitor " however nothing is displayed when the electron is booting up.
There should be something from Blynk showing that it is at least trying to connect… your Sketch may not even be getting the the Blynk.begin() command… perhaps that Particle.keepAlive(PARTICLE_KEEPALIVE); is stalling something? I am not familiar with any of the Particle devices to know what else to suggest??..
Hey @Gunner, I think the problem was signal strength…the very next day I took the particle to a different location and it hasn’t missed a beat since.
