Packet too big and Wasn't online yet using Arduino
I don’t know whats wrong :frowning: The serial monitor always said connecting…packet too big. My Bluetooth also sometimes cannot be connected somehow. And there’s a message in the blynk app saying Wasn’t online yet. What to do guys?
#include <HX711_ADC.h>
#include <Wire.h>
WidgetLCD lcd(V2);
char auth[] = "Bbixez5jmpQXDQatBXIV9LHDGRrWAY2z";
int switchPin=7;
float weight;
HX711_ADC LoadCell(9,10);
  pinMode(switchPin,INPUT);
  //Motor=0;
  LoadCell.begin();
  LoadCell.start(500);
  LoadCell.setCalFactor(1171);
  Serial.begin(38400);
  Serial.println("Setting up");
  Blynk.begin(Serial, auth);
  Serial.println("Connected");
  if (digitalRead(switchPin)){
    LoadCell.update(); // retrieves data from the load cell
    float i = LoadCell.getData(); // get output value
    //Motor=map(i,0,1023,0,255);
    //analogWrite(5,Motor);
    Blynk.virtualWrite(V3,i);
    delay(2000);
    lcd.print(0,0,"Mixing waste");
    //Serial.print("Mixing ");
    Serial.print(i);
    //Serial.println("grams of waste");
  else {
    Serial.print("Turn on the switch to mix ");
    //Motor=0;
    lcd.print(0,0,"WasteNova static mode");
    lcd.print(0,1,"Bacterial activity on going");
@Student please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Hi @PeteKnight
I edited the code, now it’s better, thanks!
Do you have suggestions for my problems? I am using Bluetooth module hc05
You’re doing two things wrong…
  1. your serial port is being used for both communication with the Bluetooth module, and Blynk/Debug messages. This will mean that the Bluetooth module is seeing data that it’s not expecting, and won’t know what to do with it.
  2. you have a very cluttered void loop, and it also contains blocking delays. You need to use a timer to solve these problems.
The solution to (1) will depend on which Arduino board you are using. If it’s a Mega then simply use a different hardware serial port for the Bluetooth module. If it’s a Uno/Nano then you’ll need to create a software serial port, but this won’t work for speeds above 9600 baud, so you’ll need to reconfigure your Bluetooth module to work at this speed.
Read this;
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/keep-your-void-loop-clean
for information about how to solve issue (2).
