Output Data Every Half Second
Hello!
As it stands now, when I export my findings as a CSV, I get results every second. I wanted to see if BLYNK allowed for me to get data every half second.
To get more specific: I’m trying to capture finger pressure in as granular a fashion as possible. I want to try to see the exact moment pressure stops being applied to something; if I can output data every half second as opposed to every second, that’d be very helpful.
Thank you for any help!
Hardware: Arduino MKR 1010 WiFi; one force sensor and wiring
Using BlynkSimpleWiFiNINA
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
/*Description:
  Circuit:
    Arduino        Component
  mkr1010 wifi
      A0  ------->  FSR0
      A1  ------->  FSR1
      A2  ------->  FSR2
      A3  ------->  FSR3
      A4  ------->  FSR4
// Libraries
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
// Pins definitions
#define force1SensorPin A0 // the FSR and 10K pulldown are connected to A0
//#define force2SensorPin A3 // the FSR and 10K pulldown are connected to A1
//#define force3SensorPin A2 // the FSR and 10K pulldown are connected to A2
//#define force4SensorPin A3 // the FSR and 10K pulldown are connected to A3
//#define force5SensorPin A4 // the FSR and 10K pulldown are connected to A2
int analogReading_FSR1=0;
//int analogReading_FSR2=0;
//int analogReading_FSR3=0;
//int analogReading_FSR4=0;
//int analogReading_FSR5=0;
/* Fill in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "TMPLTcmcwxfq"
#define BLYNK_DEVICE_NAME "Finger Pressure"
#define BLYNK_AUTH_TOKEN "TSUhqRhOhdaFi62Pr56vrK_qcZvuLxNY"
// Declaring variables
char ssid[] = "ATT2YaCIwK";            //**  your network SSID (name) between the " "
char pass[] = "psxg9#9922#u";            // your network password between the " "
int keyIndex = 0;            // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; // connection status
String ipAdress;
WiFiServer server(80);       // server socket
WiFiClient client = server.available();
unsigned long timeSensor=0;
  while (!Serial);
  enable_WiFi();
  connect_WiFi();
  server.begin();
  printWifiStatus();
 // Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
  Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
void loop(){
 if(millis()-timeSensor>50){
  readSensors();
  timeSensor=millis();
    printWEB(analogReading_FSR1);
void readSensors(){
   analogReading_FSR1 = analogRead(force1SensorPin); //**
   Serial.print(analogReading_FSR1); Serial.println();
    Blynk.virtualWrite(V0, analogReading_FSR1);
void printWifiStatus(){
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
void enable_WiFi(){
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE)
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true)
  String fv = WiFi.firmwareVersion();
  if (fv < "1.0.0")
    Serial.println("Please upgrade the firmware");
void connect_WiFi(){
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED)
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
void printWEB(int sensor1)
  if (client)
  {                               // if you get a client,
    Serial.println("new client"); // print a message out the serial port
    String currentLine = "";      // make a String to hold incoming data from the client
    while (client.connected())
    { // loop while the client's connected
      if (client.available())
      {                         // if there's bytes to read from the client,
        char c = client.read(); // read a byte, then
        Serial.write(c);        // print it out the serial monitor
        if (c == '\n')
        { // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0)
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println("Connection: close");  // the connection will be closed after completion of the response
            client.println("Refresh: 0.50");  // refresh the page automatically every 1 sec
            client.println();
            // this part is the content of web site
             client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the table
            client.println("<style>body { text-align: center; font-family: \"Trebuchet MS\", Arial;}");
            client.println("table { border-collapse: collapse; width:35%; margin-left:auto; margin-right:auto; }");
            client.println("th { padding: 12px; background-color: #0043af; color: white; }");
            client.println("tr { border: 1px solid #ddd; padding: 12px; }");
            client.println("tr:hover { background-color: #bcbcbc; }");
            client.println("td { border: none; padding: 12px; }");
            client.println(".sensor { color:white; font-weight: bold; background-color: #bcbcbc; padding: 1px; }");
            // Web Page Heading
            client.println("</style></head><body><h1>Finger Pressure Reading</h1>");
            client.println("<table><tr><th>MEASUREMENT</th><th>VALUE</th></tr>");
            client.println("<tr><td>FSR 1</td><td><span class=\"sensor\">");
            client.println(sensor1);
            client.println(" g</span></td></tr>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
            break;
          { // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r')
        {                   // if you got anything else but a carriage return character,
          currentLine += c; // add it to the end of the currentLine
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
You can only send 10 pieces of data per second to Blynk, so if you’re wanting to send just one parameter twice per second then that’s okay, but if you want to send additional data as well then it might be an issue.
You’d need to use raw data, which isn’t an option with the free Blynk plan, if you want to export the results.
You might be able to see the info in the live view screen of Superchart with the free plan, but this is limited to one datastream in the free plan so may not be that useful.
Personally, I’d probably use a time-based system using RTC and record the time that the event you’re interested in occurs.
Blynk is an Internet of Things control and monitoring system that isn’t really designed to show data to the type of granularity that you’re looking for, as it’s not really relevant to an IoT environment.
Gotcha, thanks for the response, Pete!
