Hello respected Sir
Can I open the serial monitor in arduino IDE through virtual ports that can be created by using Virtual serial port emulator or any other softwares if possible then which type of virtual port should i create in order to achieve this task?
Blynk is the best
Thanks in Advance
While Blynk does have Virtual pins, this is not a Blynk related question. I think you will need to Google that one.
Kay thanks
But What your knowledge says bro?
Is it possible Then i should tend toward google
Basic RS232 Serial is one of the simpler data protocols, should be easy enough to virtualize… but over what real protocol and why, that is the question (but a rhetorical question… this is NOT the forum for this discussion).
Ok by the way thanks for the help Gunner bro
Blynk The Great!
