Hey guys I’ve made a line follower robot that is supposed to go to the specific rooms it’s assigned to through the app. I have 3 buttons for rooms 1,2, and 3 respectively on the app, but my robot only responds when I press Room1 and not when I press room2 or room3 buttons. I’ve assigned the virtual pins accordingly on the app.
I’m using the ESP8266 with Wi-Fi, two IR sensors for line following and an ultrasonic sensor for collision avoidance.
The buttons worked for me before I added the Ultrasonic sensor and have no idea why it’s not working now.
The code is as follows:
#define motorPin1 D0
#define motorPin2 D1
#define motorPin3 D2
#define motorPin4 D3
#define SS1 D5
#define SS2 D6
#define trigPin D7
#define echoPin D8
int cnt1,cnt2,cnt3=0;
int room1,room2,room3;
char auth[] = "b26579b935784bf79cc19a30b60614d0";
char ssid[] = "a";
char pass[] = "12345678";
WidgetLCD lcd(V1);
lcd.clear();
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(SS1,INPUT_PULLUP);
pinMode(SS2,INPUT_PULLUP);
analogWrite(motorPin1, 0);
analogWrite(motorPin2, 0);
analogWrite(motorPin3, 0);
analogWrite(motorPin4, 0);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
BLYNK_WRITE(V6)
room1 = param.asInt();
BLYNK_WRITE(V7)
room2 = param.asInt();
BLYNK_WRITE(V8)
room3 = param.asInt();
int s1=digitalRead(SS1);
int s2=digitalRead(SS2);
Serial.print("ir1 : ");
Serial.println(s1);
Serial.print("ir2 : ");
Serial.println(s2);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
distance = (duration/2) / 29.1;
Serial.println(distance);
Blynk.virtualWrite(V5, distance);
if(distance<10)
else if(room1==1 && distance>10)
lcd.print(0,0, "On the way");
if(s1==1 && s2==1)
analogWrite(motorPin2, 350);
analogWrite(motorPin4, 350);
else if(s1==1 && s2==0)
else if(s1==0 && s2==1)
analogWrite(motorPin2, 350 );
else if(s1==0 && s2==0)
if(cnt1==0){
lcd.clear();
lcd.print(0,0, "Reached");
delay(500);
delay(500);
delay(500);
cnt1=1;
else if(room2==1 && distance>10)
if(s1==1 && s2==1)
if(cnt2==0){
analogWrite(motorPin2, 500);
analogWrite(motorPin4, 500);
delay(500);
delay(500);
cnt2=1;
else if(cnt2==1)
lcd.clear();
delay(3000);
delay(2000);
cnt2=2;
} Blynk.run();
} Blynk.run();
else if(room3==1 && distance>10)
lcd.clear();
if(s1==1 && s2==1)
if(cnt3==0){
delay(500);
delay(500);
cnt3=1;
else if(cnt3==1)
cnt3=2;
else if(cnt3==2)
delay(500);
lcd.clear();
delay(500);
delay(500);
cnt3=3;
} Blynk.run();
} Blynk.run();
