I have a joystick in my project. Here’s the specs:
- The horizontal axis has no pin assigned
- Vertical axis has a virtual pin assigned, range -1000 to 1000, squiggly thing enabled (I don’t know what that’s called)
- Output set to Split, not merge
- Autoreturn: on
- Rotate on tilt: on
- Write Interval: 100ms
Usually, it behaves just as it should. If i move the joystick all the way to the left, the vertical value remains at (or around) 0 as you’d expect. If I move it up or down, the vertical value behaves totally normally.
BUT, sometimes, in a pattern I’ve yet to identify, it gets in a mode where moving off-axis to the left or right does influence the value it’s sending. In the case of my system, the joystick controls a motor, and the motor moves erratically when this happens. I can see the joystick value for the vertical axis in the UI (upper left of the joystick control) reading out big values when I’m a little off axis horizontally but still near 0 vertically. So, it’s not just about my Arduino receiving the wrong values; the Blynk UI confirms that the joystick is being influenced by the horizontal axis when it shouldn’t.
It seems to enter this mode after a reconnect (Arduino reboot) from time to time.
I can fix this by going into settings in the Blynk app, opening the Joystick settings, and backing out again.
I’m using Blynk v 2.26.7 on Android (Google Pixel, and Asus Tablet both have this issue).
I’m using Blynk Cloud.
Not that it’s likely to be relevant, but my app is running on an M5Stack, communicating over BLE.
I think there may be a bug in here. But while we’re at it, it would be super cool to be able to lock an axis of the joystick for scenarios like this. I like the big fat control and autoreturn, but I only need a single axis for my scenario.
Not the world’s worst bug, but thanks anyway for looking into it!
