On arduino use ethernet for other service
Hi, when i do a connection with blynk.run, there’s a mode to unrun to use ehternet with other application, after that relogin with blynk?
Thanks!
@fringui yes you can disconnect and reconnect at will. We have been testing deepsleep with off for 20 seconds and on for 20 seconds whilst using Blynk. The live version will probably be sleep for 30 minutes and then wake for 30 seconds to send data etc.
The info you require is at http://docs.blynk.cc/#blynk-firmware-connection-management
