i am using old blynk , but my esp 32 going to connect and disconnect to server , where wifi is connect and when disconnect all switch are going to off , help me in this project
#include <IRremote.h>
#include <BlynkSimpleEsp32.h>
#include <AceButton.h>
using namespace ace_button;
BlynkTimer timer1;
// define the GPIO connected with Relays and switches
#define RelayPin1 23 //D23
#define RelayPin2 22 //D22
#define RelayPin3 21 //D21
#define RelayPin4 19 //D19
#define RelayPin5 18 //D18
#define RelayPin6 5 //D5
#define RelayPin7 25 //D25
#define RelayPin8 26 //D26
#define SwitchPin1 13 //D13
#define SwitchPin2 12 //D12
#define SwitchPin3 14 //D14
#define SwitchPin4 27 //D27
#define SwitchPin5 33 //D33
#define SwitchPin6 32 //D32
#define SwitchPin7 15 //D15
#define SwitchPin8 4 //D4
#define wifiLed 2 //D2
#define IR_RECV_PIN 35 //D35
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
#define VPIN_BUTTON_6 V6
#define VPIN_BUTTON_7 V7
#define VPIN_BUTTON_8 V8
#define VPIN_BUTTON_9 V9
int toggleState_1 = 1; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 1; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 1; //Define integer to remember the toggle state for relay 3
int toggleState_4 = 1; //Define integer to remember the toggle state for relay 4
int toggleState_5 = 1; //Define integer to remember the toggle state for relay 5
int toggleState_6 = 1; //Define integer to remember the toggle state for relay 6
int toggleState_7 = 1; //Define integer to remember the toggle state for relay 7
int toggleState_8 = 1; //Define integer to remember the toggle state for relay 8
int wifiFlag = 0;
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
ButtonConfig config4;
AceButton button4(&config4);
ButtonConfig config5;
AceButton button5(&config5);
ButtonConfig config6;
AceButton button6(&config6);
ButtonConfig config7;
AceButton button7(&config7);
ButtonConfig config8;
AceButton button8(&config8);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void handleEvent4(AceButton*, uint8_t, uint8_t);
void handleEvent5(AceButton*, uint8_t, uint8_t);
void handleEvent6(AceButton*, uint8_t, uint8_t);
void handleEvent7(AceButton*, uint8_t, uint8_t);
void handleEvent8(AceButton*, uint8_t, uint8_t);
#define AUTH "xxxxxxxxx" // You should get Auth Token in the Blynk App.
#define WIFI_SSID "xxxxxx" //Enter Wifi Name
#define WIFI_PASS "xxxxxx" //Enter wifi Password
void relayOnOff(int relay){
switch(relay){
case 1:
if(toggleState_1 == 1){
digitalWrite(RelayPin1, LOW); // turn on relay 1
toggleState_1 = 0;
Serial.println("Device1 ON");
else{
digitalWrite(RelayPin1, HIGH); // turn off relay 1
toggleState_1 = 1;
Serial.println("Device1 OFF");
delay(100);
break;
case 2:
if(toggleState_2 == 1){
digitalWrite(RelayPin2, LOW); // turn on relay 2
toggleState_2 = 0;
Serial.println("Device2 ON");
else{
digitalWrite(RelayPin2, HIGH); // turn off relay 2
toggleState_2 = 1;
Serial.println("Device2 OFF");
delay(100);
break;
case 3:
if(toggleState_3 == 1){
digitalWrite(RelayPin3, LOW); // turn on relay 3
toggleState_3 = 0;
Serial.println("Device3 ON");
else{
digitalWrite(RelayPin3, HIGH); // turn off relay 3
toggleState_3 = 1;
Serial.println("Device3 OFF");
delay(100);
break;
case 4:
if(toggleState_4 == 1){
digitalWrite(RelayPin4, LOW); // turn on relay 4
toggleState_4 = 0;
Serial.println("Device4 ON");
else{
digitalWrite(RelayPin4, HIGH); // turn off relay 4
toggleState_4 = 1;
Serial.println("Device4 OFF");
delay(100);
break;
case 5:
if(toggleState_5 == 1){
digitalWrite(RelayPin5, LOW); // turn on relay 5
toggleState_5 = 0;
Serial.println("Device5 ON");
else{
digitalWrite(RelayPin5, HIGH); // turn off relay 5
toggleState_5 = 1;
Serial.println("Device5 OFF");
delay(100);
break;
case 6:
if(toggleState_6 == 1){
digitalWrite(RelayPin6, LOW); // turn on relay 6
toggleState_6 = 0;
Serial.println("Device6 ON");
else{
digitalWrite(RelayPin6, HIGH); // turn off relay 6
toggleState_6 = 1;
Serial.println("Device6 OFF");
delay(100);
break;
case 7:
if(toggleState_7 == 1){
digitalWrite(RelayPin7, LOW); // turn on relay 7
toggleState_7 = 0;
Serial.println("Device7 ON");
else{
digitalWrite(RelayPin7, HIGH); // turn off relay 7
toggleState_7 = 1;
Serial.println("Device7 OFF");
delay(100);
break;
case 8:
if(toggleState_8 == 1){
digitalWrite(RelayPin8, LOW); // turn on relay 8
toggleState_8 = 0;
Serial.println("Device8 ON");
else{
digitalWrite(RelayPin8, HIGH); // turn off relay 8
toggleState_8 = 1;
Serial.println("Device8 OFF");
delay(100);
break;
default : break;
void all_SwitchOff(){
toggleState_1 = 1; digitalWrite(RelayPin1, toggleState_1); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 1; digitalWrite(RelayPin2, toggleState_2); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 1; digitalWrite(RelayPin3, toggleState_3); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_5 = 1; digitalWrite(RelayPin5, toggleState_5); Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5); delay(100);
toggleState_6 = 1; digitalWrite(RelayPin6, toggleState_6); Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6); delay(100);
toggleState_7 = 1; digitalWrite(RelayPin7, toggleState_7); Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7); delay(100);
toggleState_8 = 1; digitalWrite(RelayPin8, toggleState_8); Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8); delay(100);
void ir_remote(){
if (irrecv.decode(&results)) {
switch(results.value){
case 0x80BF49B6: relayOnOff(1); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); break;
case 0x80BFC936: relayOnOff(2); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); break;
case 0x80BF33CC: relayOnOff(3); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); break;
case 0x80BF718E: relayOnOff(4); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); break;
case 0x80BFF10E: relayOnOff(5); Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5); break;
case 0x80BF13EC: relayOnOff(6); Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6); break;
case 0x80BF51AE: relayOnOff(7); Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7); break;
case 0x80BFD12E: relayOnOff(8); Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8); break;
case 0x80BF3BC4: all_SwitchOff(); break;
default : break;
//Serial.println(results.value, HEX);
irrecv.resume();
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_4) {
toggleState_4 = param.asInt();
digitalWrite(RelayPin4, toggleState_4);
BLYNK_WRITE(VPIN_BUTTON_5) {
toggleState_5 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_6) {
toggleState_6 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_7) {
toggleState_7 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_8) {
toggleState_8 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_9) {
all_SwitchOff();
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
Blynk.syncVirtual(VPIN_BUTTON_5);
Blynk.syncVirtual(VPIN_BUTTON_6);
Blynk.syncVirtual(VPIN_BUTTON_7);
Blynk.syncVirtual(VPIN_BUTTON_8);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
digitalWrite(wifiLed, LOW); //Turn off WiFi LED
if (isconnected == true) {
wifiFlag = 0;
digitalWrite(wifiLed, HIGH); //Turn on WiFi LED
irrecv.enableIRIn(); // Start the receiver
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(RelayPin5, OUTPUT);
pinMode(RelayPin6, OUTPUT);
pinMode(RelayPin7, OUTPUT);
pinMode(RelayPin8, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
pinMode(SwitchPin5, INPUT_PULLUP);
pinMode(SwitchPin6, INPUT_PULLUP);
pinMode(SwitchPin7, INPUT_PULLUP);
pinMode(SwitchPin8, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
config4.setEventHandler(button4Handler);
config5.setEventHandler(button5Handler);
config6.setEventHandler(button6Handler);
config7.setEventHandler(button7Handler);
config8.setEventHandler(button8Handler);
button1.init(SwitchPin1);
button2.init(SwitchPin2);
button3.init(SwitchPin3);
button4.init(SwitchPin4);
button5.init(SwitchPin5);
button6.init(SwitchPin6);
button7.init(SwitchPin7);
button8.init(SwitchPin8);
WiFi.begin(WIFI_SSID, WIFI_PASS);
timer1.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
Blynk.config(AUTH);
ir_remote();
button1.check();
button2.check();
button3.check();
button4.check();
button5.check();
button6.check();
button7.check();
button8.check();
if (WiFi.status() == WL_CONNECTED)
timer1.run(); // Initiates SimpleTimer
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT1");
switch (eventType) {
case AceButton::kEventPressed:
Serial.println("kEventPressed");
toggleState_1 = 0;
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); // Update Button Widget
break;
case AceButton::kEventReleased:
Serial.println("kEventReleased");
toggleState_1 = 1;
break;
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT2");
toggleState_2 = 0;
break;
toggleState_2 = 1;
break;
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT3");
toggleState_3 = 0;
break;
toggleState_3 = 1;
break;
void button4Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT4");
toggleState_4 = 0;
break;
toggleState_4 = 1;
break;
void button5Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT5");
toggleState_5 = 0;
break;
toggleState_5 = 1;
break;
void button6Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT6");
toggleState_6 = 0;
break;
toggleState_6 = 1;
break;
void button7Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT7");
toggleState_7 = 0;
break;
toggleState_7 = 1;
break;
void button8Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT8");
toggleState_8 = 0;
break;
toggleState_8 = 1;
break;
