Hello everyone;
I have some issues about my new project. Im controlling four relays and using dht22 for humidity and temperature. Everything is good but after about 10 hours power on nodemcu, device goes offline and it doesn’t be online until I reset. Also device goes often offline and online in that 10 hours.
Details :
• Nodemcu Lolin V3
• I use Blynk server
• Blynk Library version is 0.6.1
#include <Wire.h>
#include <WiFiManager.h>
#include <DHT.h>
#include <EEPROM.h>
#include "RTClib.h"
RTC_DS1307 RTC;
char auth[] = "auth is here";
#define DHTTYPE DHT11
uint8_t DHTPin = 0;
DHT dht(DHTPin, DHTTYPE);
float temp;
float nem;
int istenen;
int relay1 = 15; //d8
int relay2 = 16; //0
int relay3 = 13; // d7
int relay4 = 12; //6
boolean relay1buton;
boolean relay2buton;
boolean relay3buton;
boolean relay4buton;
boolean rolekonum;
boolean oto;
int nemistenen;
int res;
int onboardled = 2;
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
digitalWrite(relay4, LOW);
pinMode(onboardled, OUTPUT);
EEPROM.begin(512);
WidgetLED led1(V1);
WiFiManager wifiManager;
wifiManager.setConnectTimeout(180);
wifiManager.autoConnect("Havalandırma");
pinMode(DHTPin, INPUT);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()){
// RTC.adjust(DateTime(2020, 01, 4, 17 ,07 ,00));
Blynk.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
delay(100);
nemistenen = 100;
oto = 0;
dht.begin();
led1.off();
digitalWrite(onboardled, LOW);
Blynk.virtualWrite(V21, 0);
Blynk.virtualWrite(V22, 0);
Blynk.virtualWrite(V23, 0);
Blynk.virtualWrite(V24, 0);
Blynk.virtualWrite(V15, 0);
Blynk.virtualWrite(V13, 100);
timer.setInterval(5000L, sendUptime);
BLYNK_WRITE(V13)
nemistenen = param.asInt(); // uygulamadan istenen nemin çekilmesi
BLYNK_WRITE(V15)
oto = param.asInt(); // uygulamadan auto-manual geçişi yapılması
BLYNK_WRITE(V21)
relay1buton = param.asInt(); // uygulamadan aç kapa yapılması
BLYNK_WRITE(V22)
relay2buton = param.asInt(); // uygulamadan auto-manual geçişi yapılması
BLYNK_WRITE(V23)
relay3buton = param.asInt(); // uygulamadan auto-manual geçişi yapılması
BLYNK_WRITE(V24)
relay4buton = param.asInt(); // uygulamadan auto-manual geçişi yapılması
//_____________________________________________________________________________________
void sendUptime(){
temp = dht.readTemperature();
nem = dht.readHumidity();
Blynk.virtualWrite(V12, nem); //V6 is for Temperature
Blynk.virtualWrite(V16, temp);
Serial.println(nemistenen);
if(Blynk.connected()){
loop1();
if(!Blynk.connected()){
loop2();
void loop1(){
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
WidgetLED led4(V4);
if(relay2buton == 1){
digitalWrite(relay2, HIGH); //relay2 = 2.röle relay3 = 4.röle relay4 = 1.röle
led2.on();
if(relay2buton == 0){
led2.off();
if(relay3buton == 1){
digitalWrite(relay3, HIGH);
led3.on();
if(relay3buton == 0){
led3.off();
if(relay4buton == 1){
digitalWrite(relay4, HIGH);
led4.on();
if(relay4buton == 0){
led4.off();
if(oto == 1){
if(nemistenen > nem){
led1.off();
if(nemistenen < nem) {
digitalWrite(relay1, HIGH);
led1.on();
if(oto == 0){
if(relay1buton == 1){
led1.on();
if(relay1buton == 0){
led1.off();
void loop2(){
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
WidgetLED led4(V4);
relay2buton = 0;
relay3buton = 0;
relay4buton = 0;
nemistenen = 100;
led1.off();
led2.off();
led3.off();
led4.off();
